Vararam
Old 10-23-2021, 07:26 AM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
6 Sp and Rear Diff, Plug fill after fluid levels off or while its still coming out?
Hi, I changed the Tranny and Rear fluids, Do you guys wait until the fluid is done running out to put fill plug in or do you do it when it is still running out? I did it while it was still running out and figured I may have an extra OZ or so of fluid. Both my Rear and Tranny which had factory fill ran out ran I removed the fill and the car was fairly level. The tranny also released air pressure. Should I jack it back up and let the fluid level off?
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 10-23-2021, 07:48 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Nope, you're fine.
Old 10-23-2021, 08:00 AM   #3
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
That’s perfectly fine. I always close the plug on my rear while it’s still coming out.
Bigdumogre is offline   Reply With Quote
Old 10-23-2021, 04:11 PM   #4
AlanRubin
Drives: 2010 LS
Send it...
AlanRubin is offline   Reply With Quote
