Roto-Fab
Old 10-25-2021, 09:58 PM   #1
francisco.munoz311
Drives: Chevrolet camauro v6
Smile 2014 Chevrolet Camaro LS v6 battery issues.
My Camaro has been having re occurring battery issues. The car after a couple hours of sitting drops voltage to battery saver mode and when I get in the car I can leave the key in and the volts start to increase enough for it to start, then the voltage goes back to normal after car has been started.
Brief History: I have had this car for about 10 months and in the past couple months I have replaced the alternator (800$) twice as well as the battery. there has been done some aftermarket stuff done but these things has been going on for a while now even before the installations.
What was done: new touch screen radio professionally installed and two subs with an amp the amp has a fuse holder so it should be protecting the battery from any damage.
etc.: 105,000 miles, no check engine
ask many any additional questions
francisco.munoz311 is offline   Reply With Quote
Old 10-26-2021, 12:34 AM   #2
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Had some tranny work done to one of vehicles. For some reason, they removed my remote wire from the ignition switched fuse to another one. Thus the amps and crossover stayed on. Bought a new battery since it was old. But was still dying. I used to install systems. Professional doesn't always yield professional results. Today's charging systems are really technical. Eating 2 alternators seems like the system was not designed properly. A fuse isn't really going to do much to protect anything, other than high current draw. What are the amps and speakers?
Badbubba is offline   Reply With Quote
Old 10-26-2021, 06:38 AM   #3
AlanRubin
Drives: 2010 LS
Most of the time, the radios are installed (wired) incorrectly.
You need to do a current draw test, and pull fuses one at a time, to see when the
load drops. You pull the fuse, look at the meter, then put it back in, one at a time.
AlanRubin is offline   Reply With Quote
