12-03-2020, 08:46 PM | #57 |
376 cubic inches of fun
The pinch welds are stronger and stiffer than the sheet metal on either side. That's why all car manufacturers designate them as the best lift points on unibody cars.
The lift blocks that straddle pinch welds and load the horizontal sheet metal next to them were designed by people who don't know structural design, sorry to say. |
12-04-2020, 07:04 AM | #58 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-04-2020, 07:35 AM | #59 | |
Thank you Al Oppenheiser!
(edit - added a crappy photo but you get the idea) Last edited by Gunkk; 12-04-2020 at 07:58 AM. |
12-04-2020, 08:43 AM | #60 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
This is that witty and clever statement that makes you chuckle.
12-04-2020, 10:59 AM | #61 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
You mean other than the ZL1Addons product? They DO NOT make the area around the pinch welds load-bearing. They simply make the area of the pinch weld easier to access and get a lifting device on.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-04-2020, 12:43 PM | #62 |
Drives: SWXXZL1 Join Date: Jul 2020
The provided 1/8" allen set screws are a PITA to tighten since they're so recessed within the pucks. Longer set screws may be available (?).
I replaced them with hex head grade 8 bolts. I believe the thread size is 1/4-28" to allow a better grip and torque without stripping out the recessed set screws. I also inserted 1/8" aluminum shims behind the fasteners to prevent the fasteners from digging into the pinch welds.
"Joe" does a hilarious impression of a slinky toy on stairs.
12-04-2020, 12:54 PM | #63 | |
Drives: 23 ZL1 6speed Join Date: Aug 2020
Thank you, I'm glad I'm not the only one who had struggled. They weren't terribly difficult but it was enough to say "c'mon on now". |
12-04-2020, 07:47 PM | #64 |
You can get 3/4" stainless set screws on amazon.
