12-03-2020, 11:32 AM | #15 | ||
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I figured it was as it came with the car & that is optioned on the window sticker. I never had an issue with my old car & that sat for a few months without anything. Like I said my plan was to plug it in for a day or so every couple weeks. Quote:
12-03-2020, 12:17 PM | #16 |
Drives: '21 Wild Cherry 2SS M6 Join Date: Nov 2020
I've seen Viper guys use a Battery Tender adaptor for the 'cigarette lighter' ports in the cabin.
can that be done on these? https://www.batterytender.com/Cigare...ccessory-Cable |
12-03-2020, 12:52 PM | #17 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
That confirms my thoughts. I'm not so much concerned with charging the battery as I am maintaining it.
12-03-2020, 01:03 PM | #18 |
Lots of good info in this thread. I used a C-Tek hard wired to post #4 on the fuse box. Ran the wire thru the flowtie. Well, at least I did before I escaped from NY. Now I just drive it.
https://www.camaro6.com/forums/showthread.php?t=540177
12-03-2020, 01:04 PM | #19 | |
If the info posted by Emoto is correct then the factory one is a very nice Tender/Charger. |
12-03-2020, 01:15 PM | #20 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
My model is NLA, but at the time, I tried to match what Chevy was selling. It has been several years now, so I can't recall any detail. It may also be that Chevy is now selling a different unit as well. I am pretty sure we have an AGM battery in our Camaros (is that correct?), so any charger designed for those ought to do an ok job. I have a handful of "Battery Tender" brand trickle chargers that I use for motorcycles and a tractor that I could have used, but I decided to get one of the CTEK units and see how that did. At only 4 years old, I can't really say because I think most car batteries last longer than that. Our Camaro batteries are on the small side, though, so I think that makes it important to try to take the best care possible of them.
This is that witty and clever statement that makes you chuckle.
12-03-2020, 01:18 PM | #21 |
Drives: 2021 2SS Join Date: Jul 2020
Yeah, I use the 'smart' CTEK MXS 5.0 and once it tops the battery off, it goes into a trickle charge / tender mode to keep the battery maintained for as long as you have it on the battery. It also has the "AGM" battery mode, which is what my car came with per the manual. So it adjusts for that as needed.
I just pop the connectors to the +/- terminals under the hood and close (but not latch) the hood, so the wire just feeds right out up front and out of the way. |
12-03-2020, 02:08 PM | #22 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I use the ones under the hood, with the spots that are designed for jump starting.
Have to ask a favour while I am here: can anyone tell me the thread size for the positive terminal under that cap? I don't have my car with me(I stored it at a garage away from me), and the charger I am using doesn't particularly attach to the positive terminal well. I am thinking of buying a nut so the connector can clamp down better. Quote:
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
12-03-2020, 02:39 PM | #23 | |
12-03-2020, 02:44 PM | #24 | |
(Too bad we don't have a like button here)
Current:
12-03-2020, 05:02 PM | #25 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Connected mine to the battery itself. I like this connect point, cause when not in use its hidden away, and waterproof. Ran the extended leads out under the trunk liner, where it accessible in the trunk. Back the car into the garage bay, pop the trunk..connect and done. Put the trunk lid down to keep dust and debris from entering.
I have battery tender , and a C-TEK brands. What ever you do, dont buy those cheapy $5.99, or $9.99..harbor freight battery tenders. Used one of these once on my lawn mower battery, and it boiled it dry in a month.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
12-03-2020, 05:31 PM | #26 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
I used a plastic tube to hold the O-ring connector down and then put the connector for the negative under the post. You can leave the cord the the device hang out over the fender like I do or you could fish the long end through the grill to reach the quick-disconnect plug.
I had tried some posts in the box as previously suggested, but getting one to work was frustrating (I forget why, but I got mad and did it this way).
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
12-03-2020, 06:34 PM | #27 |
This year I splurged on an Optimate trickle charger and hooked it up to the positive fuse terminal and the negative chassis terminal next to it. The thing charges/maintains like it's supposed to and looks spiffy, too.
12-03-2020, 09:48 PM | #28 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
