09-17-2020, 08:58 PM | #1 |
Drives: 2014 Camaro SS Join Date: Nov 2011
Surges when cruising at 55 plus o2 sensors
Ok so I Have a 2014 Camaro ss L99. When cruising at 55mph I noticed that it was always adjusting then kicking in causing a surging feeling. Very irritating when cruising at that speed. Never enough to Change the speed just enough to feel it. So I also ended up getting a P015B code. Had the O2 sensor replaced. Bank1 sensor 1. Anyway didn't fix the issue now I have occasional P015b and P015D codes. Bank 1 sensor 1 and bank 2 sensor 1 codes. My car also has K&N cold air intake and muffler deletes. Which was on when I bought the car used. So Since I got the code for the sensor that I just replaced I was wondering if It might be because the car needed to be tuned and not actually an issue with the a bad sensor. Also I used a OBD Scan tool today and from what I could tell all the sensors are working properly.
09-17-2020, 10:34 PM | #2 |
Drives: 2015 Camaro Join Date: Aug 2018
Is the AFM still active?
09-17-2020, 11:30 PM | #3 |
10-28-2020, 11:04 PM | #4 | |
10-29-2020, 06:08 AM | #5 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Start with a tune, even an off the shelf SCT tune should be an improvement.
Sent from my Pixel XL using Tapatalk
l99, o2 sensor, studder, surging |
