07-16-2020, 07:29 AM | #1 |
Drives: 2012 Camaro SS 45th Anniversary EU Join Date: Jun 2020
Engine Oil pressure? Is this normal on D - idle?
Hi guys,
Look this is on Drive idle. Is this normal? Or low? Dying pump? |
07-16-2020, 07:46 AM | #2 |
If my math is right that is about 30psi at full temp which I think is about right.
07-16-2020, 07:49 AM | #3 |
GPI Sales Consultant
If I'm doing this right, that looks like about 187.5KPA, which is 27psi. I would call that reasonable for hot idle in gear. Whats the cold start idle pressure look like?
Got a question about a GPI product? Feel free to shoot me a message! |
07-16-2020, 08:04 AM | #4 |
07-16-2020, 08:07 AM | #5 |
285 kpa = 41 psi.
07-16-2020, 08:09 AM | #6 |
07-16-2020, 08:10 AM | #7 |
Normal
07-16-2020, 08:11 AM | #8 |
Ahh nice if it is normal... I'm getting paranoia on this car..
07-16-2020, 09:36 AM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
How long have you had the car and what suddenly drew your attention to the pressure?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-16-2020, 09:43 AM | #10 | |
https://www.camaro5.com/forums/showthread.php?t=578098 |
07-16-2020, 10:51 AM | #11 | |
07-16-2020, 11:38 AM | #12 |
07-16-2020, 12:04 PM | #13 |
how many km on it?
07-16-2020, 12:06 PM | #14 |
l99, oil pressure |
