03-04-2019, 10:59 AM | #1 |
Drives: 1971 Camaro Z-28 Join Date: Sep 2015
Wheels size vs tires size
Having the mrr 228, z28 replicas 10'' in front and 11'' in the rear, can i use 275 in front instead of 285's combined with 305's instead of 315 ones in the rear? I dont want that tires look out of the fender or rear panel.
03-04-2019, 03:31 PM | #2 |
Drives: 2010 Camaro SS/RS 6M Join Date: Feb 2018
275 in the front works perfect as far as overall tire height for the 305 compared to the 275 I could do a little google searching for a tire size calculator to compare.
"A free people ought not only to be armed, but disciplined…” – George Washington
03-04-2019, 04:21 PM | #3 |
I always find the 275 in front with 315 at rear. The 275/40/20 with 305/35/20 can be matched without probs? The zl1 uses 285/305 combo, but think that the 285 is lower than the 275 plus wider, may go out of the fender. Some opinions here?
03-07-2019, 05:33 AM | #4 |
BUMP, looking for opinions, thanks.
03-07-2019, 09:19 AM | #5 |
Drives: 2014 yellow 2SS/RS Join Date: Apr 2015
I believe as long as your less than an inch difference in overall diameter you should be good
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
