12-09-2023, 09:15 PM | #1 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Time Trial SS 1LE "Build" (NASA TT3/Gridlife)
Might as well start one of these journals, I'll update it this winter as I add some stuff to my car and document some of the stuff I've done in the past.
Currently running NASA TT3 and plan on doing some Gridlife events next year. My car is not built specifically for either series as I don't want to do anything permanent yet or add any tune to the car, I want to stay flexible on who I run with. Car dynoed stock at 415HP (Dyno below) What affects the laptimes the most are tires and temperature. Best reference times I have for tires are at CMP where I've ran the following in close to idea conditions 1:40.7 (Supercar 3's) 1:39.7 (Hossier R7's) 1:37.5 (Hoosier A7's) Current mods for TT are Hoosier A7 tires (NASA), Undecided on Gridlife tires Girodisc Front rotor rings (OEM Hats) SPL trailing arms (rear) BMR toe rod (rear) 18x11 Apex wheels w/ ARP studs + MSI lugnuts, 26mm spacer front Sparco seat w/ 4 point RSR Studio roll bar Hawk 60's F/R Castrol SRF Mishimoto catch can Larger air scoops for front brakes 50 lbs extra weight ballast to get 3901 lbs minimum for TT3 (pictured below) Pending for future: Corbeau passenger seat Differential lockout kit - BMR aluminum Sway bars front/rear (later in the year) All videos associated with my car including some maintenance stuff and hot laps: https://www.youtube.com/@SpyderRacing/videos 12/21/2023 Front ZLE strut installed ZLE Suspension control module installed (to clear any issues with removing magride) 01/03/2024 Rear SPL Upper arm + Eccentric Lockout installed Rear DSSV + ZLE spring installed Some PhotoDump Last edited by Christian1LE; 01-03-2024 at 04:15 PM. |
12-13-2023, 03:59 PM | #2 |
Drives: Camaro 1ss Join Date: Nov 2019
Love to see more Camaro guys coming to Gridlife! There is some strong competition in their paddocks.
What class do you plan on running in? I'm assuming street GT with a 200tw tire?
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
12-13-2023, 05:51 PM | #3 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Subscribed! Lead the way man!
12-17-2023, 07:29 AM | #4 |
Yes street gt. Gridlife runs really cool coverage of their competitions. Only problem is that streetgt has such a huge price range that it's a little ridiculous. Looks like the best car to have is a C6Z06. But it will still be fun to go out there and compete.
12-17-2023, 11:50 PM | #5 | |
12-18-2023, 08:49 PM | #6 |
Parts coming in, going to install this week.
12-18-2023, 09:29 PM | #7 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
HA! Struts look already clearanced......
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
12-21-2023, 02:27 PM | #8 |
Front struts installed:
Weight of old strut ~20lbs Weight of DSSV ~ 14lbs |
12-29-2023, 04:31 PM | #9 |
SPL rear upper camber links + Eccentric lockout for rear camber.
12-29-2023, 07:51 PM | #10 |
Nice work so far! Just curious… has your camber been thrown off while tracking?
12-29-2023, 07:52 PM | #11 |
12-29-2023, 08:09 PM | #12 |
Yes, usually if I'm sliding on 4 wheels coming out of a corner and I hit a curb it would move the rear alignment off. Coming out of Oak Tree, turn 3 of VIR, and turn 3 at RA. It doesnt move much but my steering wheel will be off center. It only does it to me when I'm running slicks, you have to really be driving hard IMO. I tracked for 1 year on SC3's without any issues.
01-03-2024, 03:38 PM | #13 |
Rear struts + springs installed along with SPL Upper arms + camber lockout:
OEM strut ~ 6lbs DSSV Strut ~ 4 lbs Springs identical weight. |
02-13-2024, 09:13 AM | #14 |
Concerning the ZLE suspension swap... Am I correct in understanding that when we swap that suspension onto a SS 1LE, we can either swap in a ZLE suspension control module OR the ZLE rear diff control module to keep everything happy?
