07-11-2020, 06:16 PM | #1 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
Help me out; I know nothing about wheel swaps...got OEM Z/28s for my standard ZL1
Hey guys
I picked up a set of OEM Z/28 wheels to put on my ZL1. Just curious if the stock lugs will work, and if I will need spacers. I've never swapped wheels out before as I usually stick with stock... Z/28 wheel specs: Specs: Front Wheels Part Number 22873225 WHEEL-19X11J ALUM 11MM O/S 120X5XM14 B/C*ALUMINUM Rear Wheels Part Number 22873227 WHEEL-19X11.5J ALUM 26MM O/S 120X5XM14 B/C*ALUMINUM And of course the stock is: Specs: Front Wheels Part Number 23355790 20x10.0J 20MM O/S 12X5XM14 Rear Wheels Part Number 23355801 20x11.0J 43MM O/S 12X5XM14 |
07-11-2020, 08:42 PM | #2 |
Got my answer (and examples) from someone with them on a regular ZL1 guys. I'm good to go!
07-11-2020, 09:02 PM | #3 |
199
Drives: like a granny Join Date: Apr 2013
They fit and look great !
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
07-11-2020, 09:06 PM | #4 |
07-11-2020, 09:16 PM | #5 |
Hope you’ll post up some good pics when you’re done!
07-11-2020, 09:40 PM | #6 |
rears require nothing...fronts may require a small 5mm spacer to clear the strut if a lot of camber is dialed in. You may notch the strut for extra clearance. I have ZL1 1LE wheels which are similar to Z/28 wheels and use a 5mm spacer with stock lugs.
07-11-2020, 11:25 PM | #7 |
Drives: 2019 ZLE, 2019 GT350R Join Date: Apr 2020
SUPER jealous! I love those ‘14/‘15 Z28 wheels! I want those for my ZLE with SC3Rs. Soon...
07-12-2020, 06:50 AM | #8 |
Will definitely post up some pics. I've heard about the potential of some strut rub if using track setup (I don't hit the track, just street driving). I might do a spacer just to play it safe.
07-12-2020, 10:38 AM | #9 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Great looking wheel. I’m kinda biased though
07-12-2020, 11:39 AM | #10 |
Drives: 2015 Camaro Z/28 Join Date: May 2019
Nothing wrong with the stock ZL1 wheel.
07-13-2020, 10:24 AM | #11 |
Drives: 2019 ZL1 A10 Join Date: Aug 2018
Those Z28 wheels are badass.
07-13-2020, 11:03 AM | #12 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
Has anyone put the Z28 wheels on a 1LE? I'd like to know if there are any fitment issues. That is my favorite wheel of all time. Badass!
07-13-2020, 11:12 AM | #13 |
Me. No fitment issues at all
07-13-2020, 01:31 PM | #14 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Other than it being a 20" wheel.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
