09-02-2019, 08:37 PM | #1 |
Drives: SS 6 speed of course Join Date: Jan 2016
factory service manaul
Ok had to reformat and reinstall my windows so I hosed my pdf of the factory repair manual. Where is the best place to get the pdf for cheap? One day if I keep my ride I'll get the real paper manuals all 6 of them.
Any help would be appreciated. Also if anybody has installed a new LT1 pump, I'd like some hints. I've installed and centered LS pumps with shims, but this new variable vane pump
09-03-2019, 12:06 AM | #2 |
Drives: 2017 2SS M6 Join Date: Jun 2013
I could send you a SD card with it its 256mb so too big to email it. ill see if i have a card. i could just send it in and envelope.
09-03-2019, 05:20 AM | #3 |
Drives: Camaro Coupé 2.0T AT8 (EU version) Join Date: Mar 2016
There you go:
https://drive.google.com/file/d/1WUC...WZHL66nVMFEqiY |
09-03-2019, 06:12 AM | #4 |
I pulled the front cover off of the pump and slid three shims, equally spaced between the drive gear and rotor. I believe I used .003 material but can’t remember for sure.
For what it’s worth, IMHO, the plastic bolt sleeves do a good job of aligning the pump. The alignment tool that is referenced in the shop manual sets the pump in the Y direction. What about the X? Isn’t the pump as just as likely to be misaligned side to side? I don’t think gravity is much of a factor.
Baby Blue
09-03-2019, 09:43 AM | #5 | |
Drives: 11 Corvette ZR1 Join Date: Jul 2017
Does it work for the 18 SS or do you have it? Thanks
Jay Quote:
11 Corvette ZR1
18 Lexus GX460 19 Yamaha FX Cruiser SVHO |
Thread Tools | |
