08-09-2018, 09:03 PM | #1 |
Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
Finally some numbers!!
Had a friend of mine do some pulls for me. Whether or not it’s a “happy” dyno, I don’t really know. I’m just glad I finally have some numbers to work with. Special thanks to Ted @ Jannetty Racing for everything he has done. The tune is spot on and the car runs and drives excellent. Also thanks to everyone on this forum for the suggestions along the way. Very happy with the results and I’m fairly confident I will soon join the 10 second club!
Mods: Procharger P1SC-1 with race IC (3.7 pulley) Stock manifolds, catless off road pipes, stock NPP LT4 HPFP, injectors, ZL1 in tank, FP voltage booster, 93 pump gas Jannetty custom remote tune (Ted)
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
08-09-2018, 10:58 PM | #2 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Congrats! That is awesome! You should be well on your way to 10 second club.
Do you know how much boost you are running?
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
08-10-2018, 04:53 AM | #3 |
Thank you Al Oppenheiser!
Nice. Planning on any internal mods to keep up with those impressive numbers?
08-10-2018, 06:35 AM | #4 |
Drives: 18 zl1 Join Date: Aug 2017
that is impressive. even still with plenty of room to grow.
08-10-2018, 06:53 AM | #5 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Nice!. I could live with that!.
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
08-10-2018, 07:40 AM | #6 |
Just over 10psi. I have seen it 11.5 on street logs. But that’s really only close to max RPM that it gets that high. Although, I can’t remember if that was with the stock cars restricting it or not.
08-10-2018, 07:45 AM | #7 | |
www.jannettyracing.com
08-10-2018, 09:26 AM | #8 |
08-10-2018, 09:46 AM | #9 |
sounds good!!
2016 NFG 1SS A8
08-10-2018, 10:19 AM | #10 |
Thanks guys. Next year (after the wedding) I may be allowed to do a cam and forged internals. But I’ve pretty much spent everything that I can for right now without being kicked out of my bed. Very close though.
08-10-2018, 10:55 AM | #11 |
Drives: SS 6 speed of course Join Date: Jan 2016
a good couch is a great upgrade for even the best marriages.. just saying. Luv the blue color.
So the car has no cats at all correct? Sound really tame compared to my car. OK not to throw bombs, I'm just point out that the P1sc can and does put out more than double the factory torque just before 3 grand. So I honestly at least for me on street tires don't know why the PD guys keep saying that the centri lacks torque. Don't know! My car can't hook its power to the ground in the first two gears on street tires period.. I can be as gentle and roll into the power all I like, even a small centri will just eliminate any street DD radial tire at an legal speed. Just a really great power torque curve from a P1S and a near stock install.
08-10-2018, 11:10 AM | #12 |
Most P1 dynos don't look like that. That is the best looking torque I have seen from one yet.
2016 NFG 1SS A8
08-10-2018, 11:28 AM | #13 | |
I’m not going to lie. I could believe the torque. He did 5 runs and it was pretty damn consistent too though. Maybe it’s Teds magical tune. Appreciate the comments.
08-10-2018, 12:06 PM | #14 | |
I think the smaller pulley is just spinning the supercharger into its sweet zone that much sooner.... yet there is still good head room at the top for serious HP... It would be cool if the same shop can overlay a stock ZL1 dyno over this one.
