Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro Convertible
Old 01-02-2020, 12:15 PM   #1
Ajs16400
Drives: 2017 Camaro SS Convertible
Qtr Window Wind Noise
Lets hope i het more responses with information then i have looking for black leather knee pads. I started hearing noise coming between the main window and my qtr window. Vehile is still under warranty brought it up when other work was getting done and they just seemed to ignore it. It can be heard coming from both sides i notices part of the seal is flattened is that normal on these? Can all who read just respond with if you have the noise and if you seal on the qtr window as this weird bend to it.
Ajs16400 is offline   Reply With Quote
Old 01-02-2020, 06:06 PM   #2
Ajs16400
Seriously it takes just a few seconds to look and post. Please help me out here.
Old 01-02-2020, 09:58 PM   #3
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Yours definitely has more wear in than mine. Regardless, both Gen 6 Verts I’ve owned have a mild wind noise (from that general area) at speeds over 60MPH. I don’t worry about it since I almost entirely drive with the top down.
Chutzpah is offline   Reply With Quote
Old 01-02-2020, 10:20 PM   #4
Ajs16400
Thank you so much for the reply.
Old 01-02-2020, 11:49 PM   #5
Ron2ss
Ron2ss's Avatar
Drives: 2020 2ss vert
My owners manual states "The rear windows should always be raised before the front windows to ensure the best seal."
Don't know if you are doing this or not, but it may or may not help your situation.
Ron2ss is offline   Reply With Quote
Old 01-12-2020, 08:41 PM   #6
filthyfun
filthyfun's Avatar
Drives: 2017 50th Anniversary Convertible
Yes I have some wind noise as well there. I had the dealer check it out and they said yes it has some woind noise but is normal for the convertible. I didn't like the answer but I also drive top down whenever possible so I let it go. My rubber seal looks the same as the above picture.
Sent from my SM-G950U using Tapatalk
2017 2LT 50th Anniversary Edition Conv. TPW 9/26
filthyfun is offline   Reply With Quote
Old 01-12-2020, 09:05 PM   #7
Ajs16400
https://www.google.com/url?sa=t&sour...91YLNGkA83lR0j
Dealer is trying this we shall see if it works
Old 01-12-2020, 11:04 PM   #8
EddyC
Drives: Chevy Camaro 2SS
I've only noticed complaints about wind noise on the vert threads but enough people here mention it to be a "feature" rather than an fault. Honestly in all 3 of my verts I've always had wind noise, even in the folding hard top so think it's just one of the joy's of owning a vert. Read some of the threads on seal care, I've used some good products and certainly feel they reduce the noise to something bearable. If it's super bad your window might be out of alignment with is a dealer fix.
EddyC is offline   Reply With Quote
Old 01-13-2020, 09:17 AM   #9
Chutzpah
Chutzpah's Avatar
Interesting, thanks for sending along... I’ll be checking mine in the spring, more out of curiosity than anything else.
Old 03-26-2020, 09:42 PM   #10
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: 19 2SS vert, Mosaic Blk, A10
I notice it significantly more in my 19 than I had in my previous 11... But like most others, tops rarely up so I don't mind
Drago77 is offline   Reply With Quote
