06-08-2012, 06:19 PM | #1 |
Drives: Black 1SS/RS LS3 M6 "The Toy" Join Date: Dec 2011
Cam installation
About to Buy a cam just curious on the difficulty of installing the cam as I have never done this before. I prefer working on my car myself but not sure about doing the cam install myself, would hate to not get it right. So my question is is this a difficult install or can a novice do a cam install? I know we all have to start somewhere and the easy mods are no problem just need some advice on difficulty.
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
06-08-2012, 06:32 PM | #2 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
There is a pretty good diy here on it....do a search.
Still, if you have to ask how hard it is, you should at least get someone to help you who knows what he's doing because if you mess something up it could be an expensive mistake.
NY5thgen.com
06-08-2012, 06:34 PM | #3 |
Drives: '17 Fifty SS - '18 Traverse Redline Join Date: Jul 2009
Im sure someone will hook you up with some good valuable information
2017 Camaro SS -"FIFTY"
Mods: "93 Octane" |
06-08-2012, 08:26 PM | #4 |
Out Front!
I did my cam swap off Robertways DIY in the DIY section. Other than the cam swap, the most extensive install were headers. As long as you feel comfortable after reading his write up I'd say give it a shot. If you have patience and the right tools, it shouldn't be too bad. Definitely get a second hand. It helps when you get frustrated and prevents the verbal abuse to your car.
Good luck putting the oil pump back on and getting the pick-up tube aligned right. That part had me wanting to put a hole in the wall.
B Troop, 3-17CAV - Out Front
06-08-2012, 11:08 PM | #5 |
Thanks for the input still havent decided but leaning on doing myself once I order.
06-08-2012, 11:11 PM | #6 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Easy day...
Great writeup: http://www.camaro5.com/forums/showthread.php?t=125123 Ivan @ Southwest Speed |
06-09-2012, 11:14 AM | #7 |
Personally I wouldnt touch it. Its quite a bit of work.
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
06-09-2012, 11:26 AM | #8 |
Do it. Take your time and have plenty of containers and baggies to label. Give yourself a full weekend so to not be rushed and in case you run into something.
06-09-2012, 11:48 AM | #9 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
+1 on taking pictures just before disassembling something and bagging the bolts and parts.
Take your time and get the right torque specs on the items like cam sprocket bolts, timing cover bolts, oil pump bolts etc etc. I'd say the hardest part to remove and install is the damn crank pulley ( please please buy the longer bolt to reinstall the crank pulley from rpmspeed it's only a couple of bucks but worth it, if not you'll strip the beginning threads on your crank). Other than that you'll be happy you did it yourself and proud to say your ride is built not bought! Lol you can also post up here for questions and I'll subscribe to lend a hand online at least lol. Good luck bud
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
06-09-2012, 12:12 PM | #10 | |
Drives: 2009 ZR1 Join Date: May 2010
Here are your torque specs: http://www.ls1howto.com/index.php?category=1 but I believe they are listed in the DIY. Also, I used tape to label the connections, parts, etc. I also wrote the torque specs on the bags that held the parts so it sped things up when I went to put things back together. |
06-09-2012, 12:14 PM | #11 |
Thanks for all the input. After reviewing the write up I think I will do it myself. I will probably get the cam this coming week and either do this next weekend if I dont go to the track or the following. Thanks again for all the input.
06-09-2012, 12:55 PM | #12 |
V8 Lounge member #2
Awesome! Go into it thinking your going to have some fun and get to know your car better. Like a hot date that you know is going to give it up and allow you to stab her with your cam! It just takes some time to undress her that's all lol.
Ps upgrade while your there, c5r timing chain, melling oil pump, arp cam bolts,arp crank bolt and arp head bolts not head studs. If you get these you can reuse them many times and torquing them down is easier than doing the Gm torque to yield bolts that are good for one time only.
06-09-2012, 01:12 PM | #13 |
Now that sounds like good times.
06-09-2012, 01:17 PM | #14 |
chevy pride
i found a local guy that does all the ls motors and blower work around my area , its his side job, so i will endup leaving my car there for a weekend to a week depends on how much he as to work at his first job but for 200 bucks , i wouldnt chance it im sure someone in ur area could hook u up and or help u do it, its easy to mess up on the pushrods and such.
check out ky speeds fb page https://www.facebook.com/kyspeed |
