08-21-2012, 05:34 AM | #1 |
Drives: 2011 camaro 2SS RS Join Date: Apr 2012
Octane additives
I can only get 90 octane where I live, so I was wondering if by adding octane boost, will that bring 90 to say 91, 92, 93. I want to get 93 octane but cannot at the pumps here.
08-21-2012, 09:59 AM | #2 |
NJ/SoCal HT5 COTW 3/25/12
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71 Join Date: Nov 2011
One word: Torco
I add 1 32 oz can to a fill tank of crappy Cali 91 Octane and it brings it up to 97 octane. With different mixtures you can go up to 105 or more. It's bullshit, like the poser stuff they sell at Pep Boys it's the real deal |
08-21-2012, 12:07 PM | #3 |
Drives: 2021 1LE Join Date: Jul 2011
At 30 bucks a quart are u doing this with every fill up?
08-21-2012, 12:30 PM | #4 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Look at where the OP lives, this seems to be his only option.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
08-21-2012, 12:35 PM | #5 |
just go to the airport and buy jet fuel, only 15 bucks a gallon.
08-21-2012, 12:45 PM | #6 |
I Got My Orange Crush
Drives: it like I stoles it... Join Date: Jan 2011
You don't want "Jet Fuel". Jet engines use JP-4 or similar, the equivilant of diesel or kerosene. You would want Aviation-Gas (AV-Gas) for piston engines, which is similar to 104 octane.
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~ |
08-21-2012, 12:47 PM | #7 |
Dont buy jet fuel, thats kerosene. Buy av gas, or aviation fuel. Totally different animals
08-21-2012, 01:34 PM | #8 |
Drives: 2010 Camaro 2SSRS RJT L99 Join Date: Jun 2010
Jet fuel is closer to diesel the gasoline, that would be bad!!!!
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages. More to come!! |
08-21-2012, 01:36 PM | #9 |
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
08-21-2012, 01:39 PM | #10 |
I also run a quart of torco per fill up, it adds around $20 per fill up.
I have two tunes from JRE. One for 91 octane pump fuel if I take a longer trip of if I do not want to add the torco which gets me around 505-510 RWHP. I also have a +93 octane tune for use with the quart of torco which brings things to around 97 octane. With that tune I am in the 550-560 RWHP range. Does not seem like much but it is very noticable when driving the car compared to the 91 octane tune. Would be nice to have the power with the 91 but I would rather be safe then sorry and Ted makes sure things are safe! Its better then using a water/meth system for the same purpose, if that runs out or the system fails, your in serious trouble. If the torco fails, you run out of gas!!!!
Fiftydriver
08-21-2012, 05:51 PM | #11 |
Fourmz
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28 Join Date: Sep 2009
Im in Alaska as well and I use Torco. Lots of places sell it here. Stuff works great. Its 22$ for a 32oz bottle, but alot cheaper than an engine.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
08-21-2012, 07:45 PM | #12 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
as everyone has said. Torco or nothing... the others are all fakes, they don't do anything worth while.
you need this:
08-22-2012, 02:26 PM | #13 |
Drives: 2012 45th Anniversary RS Join Date: Jun 2012
so you pour all of the 32oz can into a full gas tank ? Thanks.
08-22-2012, 02:28 PM | #14 |
Formerly Camaroc5
Drives: 2010 Camaro LT/RS M6 Join Date: May 2010
Thread Tools | |
