11-23-2021, 10:28 AM | #1 |
Drives: 2014 camaro ss 1LE Join Date: Apr 2020
will 345's fit
I just ordered a new set of wheels 18X12 with a 41mm offset.
will i be able to fit 345's under my car? I am fine going with a 315 but would prefer more if I can get it. Mickey Thompson makes a 345 that i would love to run but id hate to drop a grand on tires to find out they dont fit. anyone had any luck doing this? Pics if so?
2014 SS 1LE summit white
RWHP 1032 Modifications are as follows: Engine, forged and stroked 416 CI, Procharger F1A-94 with upgraded race intercooler and big red blow off valve, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods and ported heads. Fore innovations twin 450 pumps on E-85 Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1700 Injectors, Kooks 1 7/8" Long Tube Headers , |
11-23-2021, 01:30 PM | #2 |
There’s a guy running 335’s RedjewelSS I think.
Orange Krush II
11-23-2021, 01:49 PM | #3 |
wonder what hes running?
Im looking at radials most of them are 315's but MT makes a 345 and M and H makes a 325
11-23-2021, 02:50 PM | #4 |
I am running 335/30/20's on a 11.5 inch wheel with a 30 offset and lowered 1.25. When I had my M228's on the back 11.0 wide with a 43 offset I did have the 335/30's on there as well with no issues. Here are some pics. These are the 11.5 +30's...
11-23-2021, 02:57 PM | #5 |
This one is the M228's 11.0 wide +43 offset with the same 335/30.. I was looking at the 345's not too long ago and they are only 10mm's wider that the 335's, which is only about 1/2 inch total, or 1/4 inch each side. And for the extra money for that, I said nah, stuck with the 335's.
11-23-2021, 03:14 PM | #6 | |
I dont see alot of manufacturers making that size haha. i just bought a set of 18's that are 12 inches wide with a 41MM offset. I had 315's on my car before but traction is king and love the looks of a nice wide tire tucked underneath so looking to fill that wheel well up as much as i can go.
11-23-2021, 03:38 PM | #7 | |
11-23-2021, 03:54 PM | #8 |
Here is an Apex wheel they said would fit my Camaro, 19x12 +41et.
https://www.apexraceparts.com/shop-b...aro-wheel.html
11-24-2021, 05:25 AM | #9 |
Are you sure the 18x12 wheel will clear your LCAs?
My 15x10.5s are extremely close. I cant recall the offset... With a 325/50/15 MT ET R, I had to remove the inner wheel liner on both sides. And on the passenger side, the fuel fill spout has a couple retaining screws/clips that I had to replace with cable ties (not pictured). Safety first.
2011 Camaro SS---SOLD
11-24-2021, 07:08 AM | #10 | |
11-24-2021, 07:10 AM | #11 | |
11-24-2021, 09:16 AM | #12 |
That's so awesome bro!! Post up some pics when you get them installed.. Good luck.. Gonna look great!! Nothing like having some FAT meats out back...
11-24-2021, 10:57 AM | #13 |
That beast is making some steam Kevin. 1032whp! You're gonna need some 15s on that puppy to even remotely hook on the street.
Good luck!
