10-31-2020, 11:25 PM | #1 |
Drives: 2018 A10 ZL1 Join Date: Oct 2020
Maggie 2650 Dyno numbers??
Based on magnuson, they did 730whp on a c7zo6 with a magnuson2650/intake/103 throttle with the 90mm pulley and everything else stock.. on 16 psi how come when everyone else is going 13-14.5 psi and going lower than 700whp with more mods.. i have a intake/headers and snowperformance meth,103 mm throttle body i am wondering if anyone had a similar build could help,, where am i going with the boost on stock pulleys with the boost and power.
11-01-2020, 12:14 AM | #2 |
There’s so many posts on this. Do a search, but in a nutshell about 700rwhp is what people get before running out of fuel. These are on a dyno jet with SAE.
Doesn’t matter what other bolt ons you have. No cam/meth your out of fuel. Low side booster pumps only do so much. 90mm pulley is roughly 14.5 psi, several factors can effect this. Like colder dense air as well as elevation. You have meth so you’ll make more power. |
11-02-2020, 02:16 AM | #3 |
I actually have been doing search for days, sinister life with his zl1 he made 780 with intake/headers meth and the 2650, others are claiming 700whp with the same mods, i am just lost about who to believe, also i will be running meth with 93 oct and a jmx booster.
11-02-2020, 05:34 AM | #4 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Well, as I discovered the numbers vary quite a bit depending on how the numbers were presented. Uncorrected, SAE, vs STD. In my case there is nearly a 50rwhp difference in uncorrected and std.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
11-02-2020, 07:08 AM | #5 |
There is also a large delta between dynamic and static load dynos. The delta here can be as much as 60-80 hp in the 700-800 whp range with dynojets reading higher.
11-02-2020, 03:48 PM | #6 | |
700rwhp is about the max without a cam/meth or any type of fueling mods. 730rwhp with stock fueling sounds like a glory run, in STD, or pushing it to unsafe levels. |
11-02-2020, 04:13 PM | #7 |
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
Beacuse for ever # of boost the heat increase is substantial. 30rwhp isn't worth the squeeze. Normally you see 25whp per # of boost. 700rwhp at 13# vs 730rwhp at 16# ain't worth that juice bud.
11-02-2020, 04:21 PM | #8 |
11-02-2020, 07:22 PM | #9 | |
You can make just a bit more with a blower like the mag 2650 as the power curve is a bit different and doesn't need as much down low. I'm sitting right at 690 or so with the magnuson swap (90mm pulley) , headers, nw 103mm, cat back, rotofab. Going back in the shop soon to get a cam and heads ported. |
11-03-2020, 06:50 AM | #10 | |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
11-03-2020, 06:58 AM | #11 |
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT Join Date: Dec 2019
Wrong thread
11-03-2020, 07:47 AM | #12 |
TVS 2650 potential when done right
The LT4 and its fuel system can put down some pretty crazy numbers when set up right 750 RWHP on a Superflow Most accurate dyno.
The JRE 125 RWHP package plus the TVS 2650 on 100 octane sunoco unleaded put down 740 RWHP at 16.5 psi. https://www.facebook.com/60848939090...28914431266578 Great for the street or drag racing but. But we quickly proved that it is not Road coarse worthy, Water and oil temps get way too high way too fast. I originally wanted to add a cam to this build but customers elected to not do that. Well after a weekend at the track I was able to convince him to add our Terminator cam package with 32% fuel lobe, and slow the blower down. The results are over 800 RWHP with 4 PSI less boost. https://www.facebook.com/60848939090...60709375039036 Still on the LT4 fuel system with JMS fuel system voltage booster. Along with the impressive numbers came a track record and championship this past weekend. Feel free to call with any questions.
www.jannettyracing.com
11-03-2020, 08:23 AM | #13 | |
Petro-sexual
Additionally - with Magnuson's car, that 730-RWHP was at the fueling limit, and Mike ran it out to like 7000-RPMs. That car was making around 700 to the tires, right around the OEM fuel cut-off, which is about 6600. I'm not sure what you're getting your information from, but I'm not sure how right or wrong it is. There's another video, from a Nickey-tuner, that had a ZL1 with a BG, and LTs, and was making about 740 to the tires. Their pulley sizes were a little different, but I think they were saying they were around 16-psi and they were right on the fueling limit (the rest of the car was stock). I'd be willing to bet you could easily make that kind of power with your mods', just using the meth for cooling, rather than fueling (and more if you used it for fueling). If you run a stock lower and the 90mm upper, I believe you can make upwards of 730-750 pretty easy with those mods. Dyno-tuning will allow to car to make the power that blower is trying to make. If you don't get the VVE and MAF right, the car will fight itself. I'm not sure where you're seeing the sub-700 numbers, but it'd be interesting to see the data and the builds. I also think that Magnuson's slightly de-tuned these blowers (at least mine) a bit. I'm not suggesting this is a wide spread-thing, or it was just mine, but it was pretty surprising, in a good way. There's a commonality that I found with mine that was very similar to what I found with my OEM-blower... Boost isn't everything...
11-03-2020, 08:25 AM | #14 |
Petro-sexual
It seems I'm around 700 and I'm pushing the edge. If my EQ-corrections get out much more than about 5% rich, I'm pushing mid-6s in PW and seeing my low side start to drop.
baseline, dyno day, magnuson supercharger, zl1 |
Thread Tools | |
