07-19-2019, 06:24 PM | #1 |
Drives: 2017 1ss 1le Join Date: Sep 2015
Going back to stock airbox with gm cai tune
Hey guys
I currently have the gm cai and a Mamo ported throttle body. My car is experiencing a vibration under load in certain gears that we have narrowed down to torque management pulling timing due to too much airflow. I was advised to either get rid of the gm cai or remove the potted throttle body. I’d rather keep the throttle response so I’d like to go back to the stock airbox. Has anyone ran the stock airbox with the gm cai tune still in the car. Any issues? Thanks |
07-19-2019, 06:57 PM | #2 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
If your not concerned with warranty I’d suggest a tune.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
07-19-2019, 07:04 PM | #3 |
Drives: 2016 F150 Join Date: May 2019
Interesting, I have a vibration under load like your explaining but thought it was just the torque converter shudder. I have a k&n intake and a bdx canned tune. I'm sure if you upgraded the filter in the stock box and ran the GM tune should be fine. Usually stock airboxes on these newer cars are really good.
07-19-2019, 08:23 PM | #4 |
No aftermarket tune for me. Warranty is important. I was told the maf scaling has changed with this gm tune. I just don’t want to have a problem putting the stock airbox back in and now the car runs like garbage
07-19-2019, 09:22 PM | #5 |
I’m curious if GM messes up somehow? I have the GM CAI and a pray ported throttle body and I’ve had no issues. At least not that I have noticed.
492WHP 473WTQ |
07-19-2019, 11:23 PM | #6 | |
Drives: 2016 2SS Convertible Join Date: May 2012
07-20-2019, 02:17 PM | #7 | |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Is your mass air sensor clocked in the right location???
This matters on these cold air kits.... Look at 11:29 |
07-20-2019, 11:32 PM | #8 |
Drives: 2017 2SS M6 Join Date: Jun 2013
what Night fall posted. your car and your intake is under warranty. nether needs replacement. Does the dealer know about the ported tb. they will blame that if you tell them its there. They wont know if you dont tell them.
07-21-2019, 10:11 AM | #9 |
I would put the stock throttle body back on just to see if the issue goes away. Then you should know what is what. Could also unplug the battery and reset the ECU.
Check the seal at the throttle body to manifold make sure the TB is torqued to 10ftlbs Double check MAF location and reset ECU is adjustment is made. These are the basics I would go through and probably will just because I’m f**ing crazy about everything being perfect.
492WHP 473WTQ |
07-21-2019, 11:11 AM | #10 |
Torque 89 Inch Pounds
07-30-2019, 10:49 AM | #11 |
Drives: Chevy Camaro Join Date: Jul 2019
Does this CAI really need a tune, the MAF should be able to sense and adjust the tune on it's own.
07-30-2019, 11:40 AM | #12 | |
07-30-2019, 12:55 PM | #13 |
Drives: 2016 Chevy Camaro 2SS Join Date: Aug 2012
Check your misfire count on all cylinders, might be your wiring.
07-30-2019, 09:28 PM | #14 |
Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
All it does is reset values in the MAF table, not really a “tune” per se.
2017 Camaro 2SS, Nightfall Grey Metallic, Magride, NPP exhaust, VS Forged VS12s in brushed clear coat (20x9 front, 20x10 rear), Michelin PS4’s (255/40 front, 285/35 rear)
