06-13-2016, 12:36 PM | #1 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Valve seals common on LS3?
Are valve seals fairly common to go on these cars?
I ask because when I coast to a stop, I smell raw oil. I've verified zero leaks, and it's not because I'm catless. It smells like fresh oil. Is there any way to test the seals to know for sure? If they are shot already, I'm a bit disappointed, but not a huge deal, as I'll be doing a cam hopefully this winter and I'd be able to replace them then.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-13-2016, 01:44 PM | #2 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
At 59k miles, when I pulled the heads off of mine, I had one that was bad. Easy enough to replace, but don't know if I would consider that common. Sorry I cant be of more help.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
06-13-2016, 02:01 PM | #3 |
95K on mine. Still good when I pulled them.
06-13-2016, 02:27 PM | #4 |
Drives: Camaro Justice Join Date: Jun 2007
Are you engine braking when you are coasting?
06-13-2016, 02:31 PM | #5 |
I replaced mine when I replaced my valve springs and I think only one or two looked kinda bad. No leaks here though, just replaced them since I was in there already. Even the seal where the valve spring broke looked good.
Have you noticed a drop in the oil level on the dip stick?
2010 2SS/RS
06-13-2016, 03:05 PM | #6 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Yeah definitely replace them and every gasket,seal and cover you come across while doing cam. I had a few ugly looking valve seals at 35k miles, but I blame the S.Florida heat and humidity
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
06-13-2016, 04:13 PM | #7 | |
Captain Gingerbeard
Yes. Not excessively so, but like 2500 and down I usually do.
06-13-2016, 04:16 PM | #8 | |
Captain Gingerbeard
That's what's surprising to me. Not much at all showing up in my catch can, and very little if any consumption over 2000 miles.
06-13-2016, 04:57 PM | #9 |
Weird. Is it consistent with every single time you engine brake or is it only from time to time you smell it?
2010 2SS/RS
06-13-2016, 05:34 PM | #10 | ||
Captain Gingerbeard
Engine is strong besides the oil smell. Logged with Torque, nothing out of the ordinary.
06-13-2016, 06:57 PM | #11 |
When I had the dealer do my oil pan gasket and oil cooler they dumped oil everywhere under the car. I cleaned and cleaned and cleaned some more but the car stank like oil for almost 3 months. Is it possible some oil got spilled somewhere during an oil change or repair?
06-13-2016, 07:24 PM | #12 |
06-13-2016, 07:36 PM | #13 |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
Says in post #1 he wants to do a cam soon; looks like he is currently on the stock cam.
2015 2SS/1LE/RECARO/NPP/RS/NAV
06-13-2016, 07:54 PM | #14 |
