12-17-2015, 10:03 AM | #1 |
1LE FTW
Drives: 2014 Camaro 2SS/RS 1LE Recaros NPP Join Date: Sep 2013
2014 Camaro 2SS/RS 1LE Recaros NPP Black 2200 miles
$35,000
Colorado This is 2014 Chevy Camaro 2SS/RS 1LE loaded. With RECAROS and Dual Exhaust!! This car has never seen rain, snow, any bad weather ever!! Not a single scratch has been in garage under cover when not driven. ONLY has 2200 miles. Was just a fun weekend ride. Addons = tinted windows, clear bra, tow hooks, 1LE emblems, blacked out bowties and side markers! Message me for more detail! Here is the actual build sheet: Vehicle Build Model: 1ET37-2014 CAMARO 2SS COUPE Order Number: RDXHJK Gross Vehicle Weight: 2,126 Build Date: 09/03/2013 Build Plant: 9 VIN: ********153188 OPTIONS: 01A - SEAT TRIM JET BLACK 1AS - DR PANEL GRAPHITE SILVER W/ ICE BLUE PIPING 1LE - SS 1LE PERFORMANCE PACKAGE: * SUSPENSION RIDE AND HANDLING PACKAGE * AXLE, 3.91 RATIO * 6-SPEED MANUAL TRANSMISSION * UNIQUE REAR SPOILER * TIRES, BLACKWALL * WHEELS, 20" ALUMINUM * SUEDE STEERING WHEEL * SUEDE SHIFT KNOB 1SZ - OPTION PACKAGE DISCOUNT 2SS - BASE EQUIPMENT PACKAGE 3CJ - MOLDING I/P GRAPHITE SILVER, POLYCARBONATE 4AA - INTERIOR TRIM JET BLACK 5A7 - TIRE SEALANT AND INFLATOR KIT (IN PLACE OF SPARE TIRE) 6X1 - COMPONENT FRT LH NON-COMPUTER SEL SUSP 7X1 - COMPONENT FRT RH NON-COMPUTER SEL SUSP 8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP 9L3 - TIRE SEALANT AND INFLATOR KIT (IN PLACE OF SPARE TIRE) 9X2 - COMPONENT RR RH NON-COMPUTER SEL SUSP AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN AFM - BLACK AKQ - PWR SEAT ADJUSTER, FRONT PASSENGER, 6 WAY AL0 - SENOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AMM - PWR SEAT ADJUSTER, DRIVER 6 WAY W/ PWER RECLINER AT8 - RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING ATG - REMOTE KEYLESS ENTRY AX2 - KEY COMMON AXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN AXJ - PASSENGER CAR AY0 - CURTAIN SIDE IMPACT AIRBAGS AYZ - RECARO PERFORMANCE SEATS LEATHER SEATING SURFACE, SUEDED BUCKET INSERTS FOLDING REAR SEAT/TRUNK PASS THROUGH B34 - FLOOR MATS, FRONT B36 - COVERING FLOOR MAT, LUGG COMPT. B56 - MOLDING ROCKER BODY COLOR BD8 - MOLDING BODY-COLOR ROOF DITCH C67 - AIR CONDITIONING C93 - LAMP INTR, AMBIENT D52 - REAR SPOILER D75 - OUTSIDE DOOR HANDLES DBX - MIRROR, INSIDE REARVIEW AUTO DIMMING DCP - ONSTAR PROCESSING DIRECTIONS & CONNECTIONS DD1 - POWER OUTSIDE MIRRORS DRIVER SIDE AUTO DIMMING DNS - DEALER INSTALLED INDICATOR EAL - SEAT TRIM, LEATHER APPOINTED FRONT SEATS EF7 - COUNTRY CODE, U.S.A. FCR - TRIM DOOR LIGHT PIPED BACKPAINTED FE6 - SUSPENSION RIDE AND HANDLING PACAKGE FE9 - 50-STATE EMISSIONS FHO - VEHICLE FUEL GASOLINE E10 G80 - LIMITED SLIP DIFFERENTIAL GBA - BLACK GW1 - AXLE REAR 3.91 RATIO I14 - ENGINEERING MODEL YEAR JL9 - ANTI LOCK BRAKE SYSTEM, 4 WHEEL DISC KA1 - DRIVER & FRONT PASSENGER HEATED SEATS KG4 - ALTERNATOR, 150 AMPS KS9 - KNOB TRANS CONT LEVER, SUEDE KTI - TIRE SEALANT & INFLATOR KIT (IN PLACE OF SPARE TIRE) LHD - LEFT HAND DRIVE LS3 - ENGINE, 6.2L V8 W/ SFI MAH - MARKETING AREA US, PUERTO RICO/ USVI MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - TRANSMISSION, 6-SPEED MANUAL N26 - STEERING WHEEL SUEDE NPP - EXHAUST, DUAL MODE PERFORMANCE NT7 - FEDERAL EMISSIONS SYSTEM NV9 - PWR STEERING, ELECTRIC ASSIST NZL - STEERING WHEEL MOUNTED AUDIO CONTROLS OSH - OSHAWA PLANT CODE R9N - PROCESSING CODE-SEAT RKC - TIRES, BLACKWALL RSK - WHEELS, 20" ALUMINUM SBF - RESTRAINT SEAT BELT SGC - SPARE TIRE/WHEEL NOT DESIRED NFLATOR KIT REPLACES SPARE SRM - MODEL CONVERSION CODE SRU - REAR VISION PACKAGE T3N - DAYTIME RUNNING LAMPS SEPARATE CAVITY T3Y - FOG LAMPS, FRONT T4F - HEADLAMPS HIGH INTENSITY T83 - HEADLAMPS CONTROL AUTOMATIC ON-OFF TB8 - HEADLAMPS CONTROL RH RULE OF THE ROAD TCR - SHIP THRU-GROUND EFFECT, LTD U2K - XM RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUSXM AFTER 3 MTHS U77 - ANTENNA, ROOF MOUNTED UD7 - REAR PARKING ASSIST UDD - DRIVER INFORMATION CENTER, COLOR DISPLAY UDY - COLOR INFO DISPLAY (CID) 7", WVGA, TOUCH SCREEN UE1 - 6 MTH ONSTAR(R) DIRECTIONS AND CONNECTIONS W/AUTOMATIC CRASH RESPONSE, TURN-BY-TURN NAV & 5-YEARS REMOTELINK APP KEY FOB SERVICES (ASK DEALER ABOUT GEOGRAPHIC COVERAGE). UFU - AM/FM STEREO COLOR TOUCH RADIO W/ 7" SCREEN DISPALY UG1 - UNIVERSAL HOME REMOTE UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE) UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER UMQ - GAUGES, AUXILIARY UP9 - CHEVROLET MYLINK UQA - BOSTON ACOUSTICS 9 SPEAKER AUDIO SYSTEM USR - USB PORT UTJ - THEFT DETERRENT ELECTRICAL UNAUTHORIZED ENTRY UV6 - HEAD-UP DISPLAY UVC - REAR VISION CAMERA SYSTEM V8D - VEHICLE STATEMENT US VK3 - FRONT LICENSE PLATE BRACKET VRG - VAA/COMPONENT REL COCKPIT VRH - VAA/COMPONENT REL STEERING COLUMN VRK - VAA/COMPONENT REL ROOF TRIM VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION VRN - VAA/COMPONENT REL REAR SUSPENSION VRR - VAA/COMPONENT REL TIRES & WHEELS VZ3 - LABEL, MERCURY DISPOSAL VZE - MODEL YEAR 2014 WRS - RS PACKAGE: * HID HEADLAMPS WITH LED HALO RING * LED TAIL LAMPS * DAYTIME RUNNING LAMPS XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE XR5 - POLLEN FILTER |
12-17-2015, 10:33 AM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
Beautiful car! Good luck with the sale!
12-17-2015, 11:24 PM | #3 |
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
Looks great.....I remember when mine looked like that......the day I got it. By 2200 miles it had already been to Laguna 7 times. Just for comparison sake, there is an IDENTICAL one (recaro's and all) here in the bay area with 7k miles for $31k at a local chevy dealer. good luck with the sale as it seems the bottom is dropping out on us price wise.
12-18-2015, 10:06 PM | #4 | |
Drives: 2015 AGM 2SS RS 1LE Join Date: Mar 2015
To the OP....GLWS! Car look IMMACULATE! |
12-23-2015, 09:33 PM | #5 |
Drives: 2006 Z06 Join Date: Dec 2015
Didn't see it in the build sheet, does the car have a sunroof?
12-23-2015, 10:55 PM | #6 |
Drives: 2014 2ss 1le Join Date: Sep 2011
No sunroof.
12-25-2015, 01:05 PM | #7 |
What is all covered with clear bra? Front clip and rear fenders?
12-26-2015, 08:30 AM | #8 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
Very nice, very tempting.
01-04-2016, 10:09 AM | #9 |
Drives: 2013 ZL1 V3RT Join Date: Feb 2012
sweet ride.... I will be looking to scoop up a black 1LE/ZL1 once my business takes off this year..
01-05-2016, 04:56 PM | #10 |
Would you happen to know if that bad boy will pass smog in California? Not sure myself. Thanks.
01-08-2016, 02:56 PM | #11 |
Drives: 15' CRT Camaro 2SS/1LE/RS Join Date: Jan 2016
PM Sent
01-21-2016, 04:49 PM | #12 |
1LE FTW
Sorry for delay - SOLD on XMAS eve
