Old 07-27-2019, 02:20 PM   #1
Mosaic6SS
Drives: Camaro
Catch Can proof
I have had a ADD W1 catchcan installed for about 1500 miles and I've got 13,800miles total on the car. I have been collecting about 2-3 ounces of oil every 200-300 miles. I am running the new 0w-40 Mobile 1 and expected less oil evaporation. To be fair, I have been driving kind of hard, but needless to say I am glad I have a can after seeing what I am collecting.
When I added the can, I flushed the intake with the CRC-DI cleaner. I did this To get a fresh start so I could keep track of the catchcans effectiveness. There has been many debates as to whether or not one is needed. I have had DI equipped vehicles since 2014 and learned about the valve coking phenomenon from a tech at GM. I have also been ASE certified and have an educational background in auto technology. I can assure you the problem is real. This is not an endorsement for catchcans but I just wanted to add my two cents to the debate.
My Silverado also has a catch can, but from Elite Engineering. The reason I decided to add one was because of what I saw when I removed the intake at 20K miles. The entire intake manifold and intake runners were coated in oil and there was carbon buildup on the back of the valves. I setup a cheap walnut blasting system and cleaned them off then added the can. It was very messy. Now I have 85K miles and will soon take the intake off and see how bad the valves are. I have not had the catch can on the truck the entire time, so I expect some carbon buildup.
Now back to the Camaro. This morning I took the intake off as I was curious how bad it was. I also wanted to make sure the valves were clean enough and get a few pics to compare later. There was oil coating everything and light carbon buildup on the valves. I did a manual cleaning and put everything back together. The way I cleaned it was by using the CRC-DI to soak the valve while it was closed. I then used a toothbrush and scrubbed the larger pieces off the valves. I used compressed air and a rag to blow the liquid out the runner. It worked well. I then sprayed a light coat of CRC-DI and just left it there. I put everything back together then fired it up.
I intend to drive about 30K, which will take some time, then take the intake back off and see what I've got. With that being said if you choose to do nothing you car will probably still run fine, and if its a daily driver you may not even notice any drivability issues. But the facts are you will eventually loose efficiency and a little power, however like I said before its subjective whether you will actually notice. If you have any experiences, thoughts, comments or questions feel free to post.
**Pics are before manual cleaning**
Mosaic6SS is offline   Reply With Quote
Old 07-27-2019, 04:10 PM   #2
Jsreo
Drives: 2017 2SS Manual
Is that a crack I see?
Jsreo is offline   Reply With Quote
Old 07-27-2019, 04:54 PM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
It's a parting line in the casting.
Gunkk is offline   Reply With Quote
Old 07-28-2019, 07:51 AM   #4
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
Wow! That sounds like a crazy amount for only 2-300 miles! That comes to about a quart about every 3k miles, so that alone would cause you to be 2qts low at normal oil change interval (~6k miles).
2017 Camaro 2SS, Nightfall Grey Metallic, Magride, NPP exhaust, VS Forged VS12s in brushed clear coat (20x9 front, 20x10 rear), Michelin PS4’s (255/40 front, 285/35 rear)
RCF is offline   Reply With Quote
Old 07-28-2019, 09:53 AM   #5
Mosaic6SS
Drives: Camaro
Had a little condensation mixed in with it plus a lot of WOT, downshifting and rev matching I am guessing is the reason. Usually if I drive normal there is less than half of that in the can.
Old 07-28-2019, 11:45 AM   #6
HighIron
Drives: 2024 2SS Summit White
I get about an ounce every 1000-1200 miles. The cumulative effect over the time I've had it on ( installed it when the car had 900 miles on it ) would be over 12 ounces of oil that didn't coat the intake tract.
HighIron is offline   Reply With Quote
Old 07-28-2019, 08:28 PM   #7
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
Ive got about 137000 miles on mine - no catch can despite being tempted. It runs strong and steady - but I am curious what it will look like when it gets taken apart.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 07-28-2019, 09:16 PM   #8
19-1LE
19-1LE's Avatar
Drives: 2019 1LE 1SS
Please take pics when you do!
YouTube Channel for my 2019 1SS 1LE: https://www.youtube.com/user/CubedGames
19-1LE is offline   Reply With Quote
Old 07-28-2019, 11:04 PM   #9
BWAYNE2008
BWAYNE2008's Avatar
Drives: 2018 Camaro 2SS
137000 miles! Where’d you drive to? The moon?
BWAYNE2008 is offline   Reply With Quote
Old 07-28-2019, 11:22 PM   #10
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
He's not a garage queen. I had 187k on my 5th Gen in just barely over 4 yrs.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 07-29-2019, 07:41 AM   #11
hotlap
hotlap's Avatar
The LT1 engine is going into its sixth year of production. Has anyone posted pictures showing serious valve coking? Vette or Camaro sites .
Ronald Reagan -
Old 07-29-2019, 08:05 AM   #12
IOMike
Drives: 2022 F150, 87 Monte Carlo
Only people that sell the catch cans offer "proof"
IOMike is offline   Reply With Quote
Old 07-29-2019, 09:07 AM   #13
Jeb114
Jeb114's Avatar
Drives: 2021 300
I had a can on my ZL1 2013. after 5000 mile oil change I had maybe 5 Drops of oil in the can after spirited driving. If your pushing that much oil you have a problem......
Jeb114 is offline   Reply With Quote
Old 07-29-2019, 10:24 AM   #14
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
This is what my intake valves looked like when I pulled my motor apart at 16K miles. Not bad, but 16K isn't a lot of miles. I installed a catch can when I put everything back together. I've maybe captured a couple of cc of oil, about 1/8 of an inch in the bottom of my JLT can in 3500 miles of very spirited driving - NMC road course and multiple 1/4 mile passes in addition to a couple of trips to the mountains
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
