11-16-2021, 10:14 PM | #295 |
11-16-2021, 10:15 PM | #296 |
11-16-2021, 10:23 PM | #297 |
More pics coming tomorrow
11-17-2021, 10:42 AM | #298 |
Which dampener is that reduction wise?
How many rotor hats you have an how much? An how much for the 1LE trans mount?
Orange Krush II
11-17-2021, 10:50 AM | #299 |
SICC
Drives: 2014 2SS1LE Summit White Camaro Join Date: May 2014
Interested in the dampener price
Sent from my SM-G991U using Tapatalk Last edited by SummitWhite1LE; 11-17-2021 at 11:42 AM. |
11-18-2021, 09:52 AM | #300 | |
There are 2 rotor hats, $80 shipped. 1LE trans mount, $25 shipped. I have interest in the above parts currently.
11-18-2021, 09:57 AM | #301 |
Some of these pictures of the entire oil cooler setup are blurred, I'll get more tonight.
11-18-2021, 11:56 AM | #302 |
Oil Cooler build and installed pics
11-19-2021, 01:55 PM | #303 |
11-19-2021, 01:57 PM | #304 |
Some header components, O2 sensor extensions, ARP stainless header bolts, cats and v bands. I think I have another new v band.
11-19-2021, 02:00 PM | #305 |
Z/28 CAI
12-11-2021, 03:24 PM | #306 |
The following parts are sold:
Z/28 CAI AutoBlip Brembo rotor hats Braille mount Raptor shift light UMI trailing arms DSE toe rods 1LE trans mount AFE headers Improved Racing oil cooler Z/28 suspension (DSSVs/springs/ARBs) JPSS radius rod inserts MGW Moreno plates Baer Bumpsteer kit Vorshlag plates BMR bolts Z/28 knuckles WW reservoir Z/28 thermostat 1LE F LCAs Z/28 bearings Clutch reservoir Caliper bolts Wheel studs Throttle body Brey Krause ZL1 brake lines DSE Speed Kit 1 DSE End Links ATI Damper 285/30 Goodyear 3R tires Driveshaft Bolts Helm Service Manual Gen5diy tank plate Tilton Clutch 1LE Recaro seat cover (bottom) modified ST43 pads, front 6 piston/rears, used Brembo 6 pistons Girodisc titanium shims APEX catch can Quantum brake ducts/fog light hose inlets ZL1 front 2 piece rotors GM Tow Hook Schroth 6 Point Harness ZL1 Ferodo HP1000 front pads Forza Exhaust Controller Tick clutch line SRP Pedals Still available, posted for sale here on camaro5: Gates LS3 belt Taylor plug wires TPMS Sensors Ground Cable Thanks again to all who have bought stuff. If you ever have a question, just shoot me a PM
02-08-2022, 03:22 PM | #307 |
Updated components for sale list
02-09-2022, 06:43 AM | #308 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Wonder if you’ll get your car for the spring with the way constraints are!
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
