AWE Tuning
Old 02-29-2024, 12:48 PM   #1
orange blaze
Red Hot SS
orange blaze's Avatar
Drives: 2017 Camaro 2SS
over size tires
Has anybody here on the forum put 265/40R20 tires on 9 inch rims on their Camaro? Just wanted to see if that size of tires sidewall would bulge out further than the rim. Let me know if you have pictures. Thanks.
orange blaze is offline   Reply With Quote
Old 02-29-2024, 06:13 PM   #2
Abubaca
Abubaca's Avatar
Drives: 2016 SS
I'm not familiar with every trim level, but aren't most of them 8.5" or 9.5"? On an actual 9", you shouldn't get much bulge, if that's actually what you have. 265 might bulge a little on an 8.5, and might look a little stretched on a 9.5.
Abubaca is offline   Reply With Quote
Old 02-29-2024, 07:32 PM   #3
Mike_Honcho
Drives: camaro
I put 305 on my 9.5 its fine.
Mike_Honcho is offline   Reply With Quote
Old 03-01-2024, 07:50 AM   #4
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
There are many different references/opinions on what fits but at least on this one with a chart that I like:
https://m.roadkillcustoms.com/tire-w...y-wheel-width/
it shows 265 is maximum that fits/is recommended on 9" wheels.
However, 265/40 is >2% taller than stock size - why not go with 265/35 instead as that is only ~1% shorter than stock and you get same tire width?
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 03-01-2024, 08:07 AM   #5
Abubaca
Abubaca's Avatar
Drives: 2016 SS
It's fine because...."You did it"???
No one has more legal responsibility than the tire manufacturer, and each and every tire has their recommendations for what size rim it can safely be used on. LOTS of tires including a crowd favorite Michelin PS4 say you can safely run a 275/35 on a 9" tire. While I would NOT put my life in the hand of the guy in above comment^^^, I WOULD listen to Michelin.
Old 03-01-2024, 08:42 AM   #6
BatMobileLT1
I 100% agree that the tire manufacturer is the best reference, I just didn't have the OP tire choice info so went with a more generic reference/guideline that as you noted is more conservative than the tire specific ones.
