01-20-2021, 07:37 PM | #1 |
ADM intercooler reservoir V2 pics
I have been a huge proponent for an IC reservoir as I believe it to be a necessary item. Just look under hood of any Hellcat or GT500 and you will see one. Why would GM choose to neglect this simple part and make it a complicated scenario? I can't answer that one. I had version 1 on my 2017 for 10400 miles and it performed flawlessly and I expect this one to perform the same. This is available from LSA conversion store for the LT4. Here are a few pics...no cutting or huge mess to install.
01-20-2021, 07:45 PM | #2 |
01-20-2021, 08:25 PM | #3 |
TWG1
Drives: 2019 Camaro ZLE Join Date: Nov 2019
Looks like a better mounting system than V1.0. Never had a problem with mine, but always worried the single AC bracket bolt would fail.
2019 ZLE M6
2019 ZL1 A10 (Sold) 1967 Jaguar XKE Series 1 Roadster 2021 F150 Powerboost (on order) |
01-20-2021, 08:40 PM | #4 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
That looks clean. Something i am definitely going to consider.
01-20-2021, 09:10 PM | #5 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I like it.
Looks rather factory. |
01-20-2021, 09:13 PM | #6 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
01-20-2021, 09:41 PM | #7 |
Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
That looks really good. I have been on the fence for a while about getting one. Does it install with all the factory hose connections or is there cutting involved? My concern is being able to put the system back to stock 100% easily if needed for warranty work.
01-21-2021, 07:23 AM | #8 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
No cutting involved. It comes with the extra hoses you need and other hardware.
It's easy to put it back to stock for warranty work though I bet the dealer nor GM would care about this as this doesn't damage anything and they cannot prove it does damage anything. |
01-21-2021, 07:32 AM | #9 |
Drives: Turbo 6.2 Join Date: Feb 2019
looks fantastic. Are you able to log any before/after temp?
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
01-21-2021, 07:40 AM | #10 |
I haven't logged anything as I know it works based on experience. Also, it was below freezing when I installed it last night. Car is so new and ambient temps so low that I doubt logging would show a thing.
01-21-2021, 08:43 AM | #11 |
Drives: Camaro ZL1 Join Date: May 2020
What's the capacity?
01-21-2021, 09:20 AM | #12 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
When you get a minute, can u measure the width, length, and height? I had a version 1 which i gave to my installer when i put the Magnuson on and am currently using the one it came with, however, i have a spare Carbon fiber coolant cover and would buy the version 2 if i thought the cover would fit over it.
thanks
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
01-21-2021, 09:25 AM | #13 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Can you get some pics of the hoses and the connections to the OEM locations?
01-21-2021, 09:42 AM | #14 |
