Old 12-21-2020, 08:49 AM   #1
Monty Burns
Monty Burns's Avatar
Drives: 2013 Chevrolet 2LT Camaro
2013 / Leak from brake fluid housing- Can't decide whether it's the cap or resevoir.
Is this a common setback? Some drips of fluid landing below the fluid housing unit. Any advice is greatly appreciated. Trying to attach pic for a better understanding.
Monty Burns is offline   Reply With Quote
Old 12-21-2020, 08:58 AM   #2
Monty Burns
Old 12-21-2020, 09:41 AM   #3
2thousand2
Drives: 1997 Camaro SS
Lot's of good info here - https://www.camaro5.com/forums/showthread.php?t=367329
Basically you'll need to find some thin plastic to cutout and space the rubber seal down inside the cap a bit, then the cap fits tighter.
2thousand2 is offline   Reply With Quote
Old 12-22-2020, 10:19 AM   #4
Monty Burns
Thanks so much, 2thousand2! Great logical fix! Merry Christmas and Happy New Year, bud! : )
Old 12-22-2020, 01:14 PM   #5
Tony-8
Tony-8's Avatar
Drives: 2014 Camaro RRM 2SS RS, M6 LS3 Vert
if any has dripped onto the painted area below the reservoir, clean it up as quickly as possible. This happened in my 2014 2LTRS and the paint bubbled badly where the brake fluid hit it.
My dealer blamed an aftermarket cap I had on it, but this is an issue on these cars and even my 2014 SS with stock cap isn't as tight as it should be.
Dream it - drive it!
Tony-8 is offline   Reply With Quote
Old 12-22-2020, 02:39 PM   #6
BLU DUCE
BLU DUCE's Avatar
BLU DUCE AKA=Spike III Build
I used the plastic from a gallon milk container 8 years ago. And have never had a problem since.
Old 12-27-2020, 11:47 AM   #7
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
Did the milk jug shim too, worked great!
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
