Roto-Fab
Old 11-01-2020, 07:45 PM   #1
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
New pads, brake fluid didn't increase level
Put new pads on and really suprized I didn't need to remove some brake fluid from the master cylinder, old pads were at 7mm thickness.
Level came up only a 1/4 inch in master cylinder.
Thanks
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
Old 11-01-2020, 09:01 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
7mm are thick pads still that’s about 60% of the life left
Bigdumogre is offline   Reply With Quote
Old 11-01-2020, 09:56 PM   #3
Quicksilver2SS
Thanks!
Old 11-02-2020, 06:19 AM   #4
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Brake fluid doesn’t evaporate - it’s attracts moisture which means there will be more fluid over time. You should change the fluid every time you change your brakes anyway.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
