dave@hennessey
Old 01-05-2016, 08:05 PM   #211
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Don’t forget our bumper mounted ZL1/SS Super Chiller has come with the mounting bracket and hardware since 2013
TrekGTO is offline   Reply With Quote
Old 01-07-2016, 05:26 PM   #212
TrekGTO
TrekGTO's Avatar
Our largest Interchiller kit 18.3" is the only chiller of this size on the market that can mount to the rear of the ZL1 crash bar without cutting into the crash bar, with stock Heat Exchanger.
Old 01-07-2016, 10:28 PM   #213
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
Is the OEM front heat exchanger at this point doing anything much other than acting as a fluid reservoir?
Can it be eliminated for a fluid tank?
2011WhiteSS is offline   Reply With Quote
Old 01-08-2016, 12:06 AM   #214
TrekGTO
TrekGTO's Avatar
Yes I have several customers that went without a H/E. As long as you use AC 100% of the time, this makes installation EZ and more room for Chiller.
Old 01-08-2016, 06:45 AM   #215
2011WhiteSS
Good to know. More room for Trans and oil cooler placement. Maybe a fluid tank for a air/water intercooler for a turbo install. 🏻
Have you adapted this kit for a turbo car with a A/W cooler for anyone?
Old 01-09-2016, 05:21 AM   #216
TrekGTO
TrekGTO's Avatar
We still make the original SS kit that wont interfere with heat exchanger and trans coolers that don’t leave room for the bumper mounted Interchiller. These work fine up to 700HP and I still have that core on my GTO @ 10PSI. These are on many Maggie, Whipple, KB, Lysholm and Harrop Super Chargers. Whipped416 used this kit since 2012 and is still on the car with new owner. We used this core on every installation until I came out with the 30% larger kit and then the first 18” Xtreme Kits in 2013.
http://www.camaro5.com/forums/showthread.php?t=196968
I made these brackets to relocate the SS kit when Whipped416 went to a ZL1 bumper cover so he could continue to use the same Super Chiller Kit. Chiller mounts fine farther back but the coolant reservoir has to be moved / replaced.
Old 01-09-2016, 05:42 AM   #217
TrekGTO
TrekGTO's Avatar
I have done some odd ball Turbo / Procharger installations that involved converting from air to air to air to water, no Camaros. But we recommend SD tune or the MAF has to be relocated before the Chiller core. There are also some insane intakes available that have the intercooler inside. I have been talking to one manufacture about doing some testing and more.
The GM TT V6 is a perfect candidate for this as an example.
Whiteside Customs Super Street 1 Package - Install Thread Whiteside Customs Suspension / Brakes / Chassis 5 12-12-2011 08:40 PM
Drag Racing..."Real Street Cars" Steve Dallas Dragstrip and Launch Techniques Discussion 40 09-04-2011 11:02 AM
Portable Dynamometer added to Houston Super Chevy Show Midway, Sept. 11-12 Houston Raceway USA - Texas 6 09-01-2010 11:26 PM
LG g6x3 or Super Charger Cam!!! Your Thoughts Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 01-24-2010 01:45 PM
Shelby Super Snake KILLER74Z28 General Automotive + Other Cars Discussion 18 07-23-2007 07:12 PM
