Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 01-27-2013, 07:57 PM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Brembo expands Michigan plant to equip all C7 Corvette Stingrays with Brembo Brakes
Via Detroit Free Press
Italian supplier Brembo has expanded its Michigan plant to produce brakes for the new 2014 Chevrolet Corvette Stingray.
Previously, Brembo supplied small numbers of brakes to the $111,600-plus Corvette ZR1 supercar. This is the first time the company, which specializes in lightweight, high-performance brakes, has supplied all Corvette models. Its factory in Homer, near Jackson, will assemble the brake discs and calipers into corner units that include bearings and knuckles.
Brembo ships the corner units to the Corvette assembly plant in Bowling Green, Ky.
North America has become Brembo's second-largest market since it opened a tech center in Plymouth in 2010.
2014 Corvette Stingray Brembo Brakes Specs:
Standard Brembo brakes, with four-piston fixed calipers derived from racing, deliver exceptional stopping power on the street or track. System highlights include:
  • 12.6-inch (320 mm) front rotors and 13.3-inch (338 mm) rear rotors are standard and have 35 percent more swept area than previous-generation brakes. Consequently stopping distance is improved 9 percent
  • Dual-cast, slotted 13.6-inch (345 mm) front rotors and 13.3-inch (338 mm) slotted rear rotors are included with Z51 Performance Package. They have 6percent more swept area than the previous-generation Grand Sport and are cooled front and rear for improved track capability. Consequently stopping distance is improved 5 percent
  • All brake packages have fixed front and rear calipers are stiffer for more even pad wear, reduced drag and improved modulation.
Attachment 543
Tran is offline   Reply With Quote
Old 01-27-2013, 08:50 PM   #2
Stingray
just can't get enough
Stingray's Avatar
Sweet. That gets 4 for each wheel.
Old 01-27-2013, 08:57 PM   #3
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Awesome!
Performance driven to the infinite degree.
GaBoy25 is offline   Reply With Quote
Old 01-28-2013, 11:23 AM   #4
Gohan
Guest
Posts: n/a
Ahh I liked me those big fat brakes. Beautiful.
Old 01-29-2013, 10:10 AM   #5
radrace19
Drives: Pontiac G8 GXP
Intersting how the new Brembos don't have the external crossover fluid tube.
radrace19 is offline   Reply With Quote
Old 01-29-2013, 10:26 AM   #6
Stingray
Stingray's Avatar
No Brembo word & logo on the calipers in the live shots... but no complaints here, it also looks awesome w/ the black rims! :rockon:
Old 02-26-2013, 01:04 PM   #7
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
yeah this is super good news. Brembo is on top of their game for sure.
PfadtRacing is offline   Reply With Quote
Old 02-26-2013, 06:31 PM   #8
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
12.6-inch (320 mm) front rotors and 13.3-inch (338 mm) rear rotors are standard and have 35 percent more swept area than previous-generation brakes. Consequently stopping distance is improved 9 percent.
That is awesome, but does it mean 60-0 is less than 100 feet?
Shark72 is offline   Reply With Quote
Old 02-27-2013, 10:17 PM   #9
Stingray
Stingray's Avatar
The 2014 Corvette Stingray’s Z51 Package Will Use SANLUIS Rassini Composite Rotors
The new Stingray (w/ Z51 PP) will come with a set of high-performance brakes developed by Sanluis Rassini. This new system uses the industry’s first rotor with a ductile iron hat and gray iron brake plates. This combination allows for a weight saving of about 18 percent and it improves the braking system’s heat-management capabilities.
This special rotor uses an I-Beam extension design, and not a solid one like the majority of the brake systems. It is also the only composite rotor on the market that can accommodate a drum in hat, a rotor design in which the internal surface of the hat serves as a brake drum.
Old 03-13-2013, 04:12 PM   #10
Johnny vette
Drives: 2014 C7
anyone know how many colors, these calibers come in ?
Johnny vette is offline   Reply With Quote
Old 08-18-2013, 02:38 PM   #11
SCM_Crash
SCM_Crash's Avatar
Drives: 2014 Z51 3LT
Yellow, red, black and silver
1997 Formula Firebird
2002 Trans Am WS.6
1990 Z32 300zx
2002 Corvette Z06
2003 Corvette Z06
2014 Corvette Z51
SCM_Crash is offline   Reply With Quote
Old 08-18-2013, 02:44 PM   #12
Drives: 2023 GMC Canyon, 2020 Colorado
Actually:
Metallic Gray - Standard
Black - Standard on Z51
Yellow/Red - Optional
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
