11-01-2020, 07:45 PM | #1 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
New pads, brake fluid didn't increase level
Put new pads on and really suprized I didn't need to remove some brake fluid from the master cylinder, old pads were at 7mm thickness.
Level came up only a 1/4 inch in master cylinder. Thanks
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
11-01-2020, 09:01 PM | #2 |
7mm are thick pads still that’s about 60% of the life left
11-01-2020, 09:56 PM | #3 |
Thanks!
11-02-2020, 06:19 AM | #4 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Brake fluid doesn’t evaporate - it’s attracts moisture which means there will be more fluid over time. You should change the fluid every time you change your brakes anyway.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
