02-28-2022, 08:17 PM | #1 |
Impact Wrench Size to Remove Steering Wheel
For guys who removed your steering wheel. What size impact wrench did you use 1/4" 3/8" or 1/2" to remove the T50 torx screw torqued to 22 ft lbs?
02-28-2022, 10:26 PM | #2 |
Drives: 2016 F150 Join Date: May 2019
I just used a 3/8" ratchet. But have used a 1/2" impact on my 6th gen
03-01-2022, 07:33 AM | #3 |
Did you have to use a breaker bar with the 3/8” rachet?
03-01-2022, 07:38 AM | #4 |
No, it was on there tight but I got it off fairly easy. I swapped out a wheel in a guys 2020 SS and it was on there incredibly tight. I broke 2 torx heads and used both an impact and then a big breaker bar. But my 2012 wasnt as tight and my 2018 came off easily with an impact
03-01-2022, 07:38 AM | #5 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
I use a impact driver to break it loose and a 3/8 impact to remove and install. If you've ever stripped out that torx bolt you'd understand why!
03-01-2022, 09:02 AM | #6 |
Hey guys thanks for the replies. Seems the degree of difficulty in removing the screw varies based on your experience and from what I’ve seen in YouTube vids. I would assume the wheels were put on manually at the plant as opposed to robotic given that the center lines have to line up and painted markings I’ve noticed that show the alignment. The spec calls for the wheel to be torqued to 22ft lbs which I wouldn’t think is all the much to cause to cause the difficulty some have had. Maybe the cause for varying difficulty is they’re variably torqued at the plant but I wouldn’t think so I guess I’ll first try using a 3/8” impact wrench. Thoughts, comments welcomed.
03-01-2022, 09:11 AM | #7 |
May be less the the initial torque applied and more the amount of thread locker (and maybe type) used?
03-01-2022, 09:14 AM | #8 |
03-01-2022, 09:22 AM | #9 |
They absolutely use thread locker....blue I think. That's why I recommend breaking it loose with a impact driver first! Trust me I've stripped the torx part out of that bolt before....you will learn words you didn't know! I've removed around 200 of these....you need to trust me on this.
Steering Wheel Bolt Procedure Prepare the steering wheel bolt for installation as follows: Remove all traces of the adhesive patch from the steering wheel bolt. Clean the threads of the bolt with denatured alcohol. Apply thread locking adhesive to the steering wheel bolt. Adhesives, Fluids, Lubricants, and Sealers Ensure there are no gaps in the thread locking adhesive along the length of the filled area of the threads on the bolt shaft. Caution: Fastener Caution. Note: The ONLY acceptable bit for removing and installing the steering wheel bolt is a T50 bit. Do NOT use any other size bit or a worn T50 bit or the bolt recess MAY strip and the bolt may NOT be removable. If a power tool is used to remove the steering wheel bolt, the tool must have a torque rating greater than 75 Y (55 lb ft) and both the power tool and the T50 bit MUST be positioned perpendicular to the bolt recess. Tighten 30 Y (22 lb ft) |
03-01-2022, 10:36 AM | #10 |
Great feedback! THANK YOU! Good to know. A impact driver and 3/8” impact wrench it is
03-01-2022, 02:27 PM | #11 |
I had no issue and used a regular 1/2 socket wrench when I removed mine.
03-01-2022, 08:29 PM | #12 | |
the wheel opening) others not having loctite (no colored stripe). Just a hunch. |
03-02-2022, 04:45 AM | #13 | |
Life is short, drive it like you stole it! |
03-02-2022, 07:03 AM | #14 |
Applying heat would be awful risky with all the wiring there. You’d have to be VERY VERY careful.
