02-22-2022, 08:57 AM | #1 |
Constant power dash fuse box
I need to tap into a constant power fuse in the dashboard/driver side fuse box. I’m already using fuse 23/trunk button for constant power. I’m thinking of using fuse 14 /Onstar as I’m assuming that’s gotta be constant power. Thoughts?
02-22-2022, 09:02 AM | #2 |
I could be wrong (wouldn't be the first time nor the last) but I'm pretty sure everything in the interior driver side fuse box is constant power. I've always had to go to the fuse box under the hood to find switched circuits.
02-22-2022, 09:15 AM | #3 |
F18 is switched power. F17 maybe as well?
02-22-2022, 09:29 AM | #4 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Fuse 2 feeds the data link connector terminal 16. It's hot at all times and protected by a 7.5 amp fuse. A whole lot easier to tap into it at the dlc than at the fuse block. It's the same terminal that powers your scan tool.
02-22-2022, 09:53 AM | #5 |
Those might be. I went to check mine but forgot the battery is unhooked at the moment. I'm curious about those two now as well.
02-22-2022, 10:13 AM | #6 |
Why would it be ezer to tap into it at the DIC?
02-22-2022, 12:30 PM | #7 |
DLC...the connector you plug your scan tool into! It's right under the dash. You can splice into that wire a whole lot easier than accessing the back of the fuse block. Nice thing about that wire is that it is a dedicated circuit only intended to power your scan tool. So it will be able to support just about anything your trying to connect and if you need to use a scan tool just turn that device off and you'll be fine.
02-22-2022, 12:36 PM | #8 |
02-22-2022, 12:55 PM | #9 | |
02-22-2022, 01:43 PM | #10 |
Glad I can help you guys. It's hard enough to fix these cars even with the right information. Don't know how you guys do it, but if I can save some head scratching I will. I fix these cars day in and day out for a living....all of my experience is with mostly stock vehicles, and most under warranty. I joined this group to learn more about modifying these cars....what works/ what doesn't. So I'm sure the more that I can give will come back to me with the more you guys know that I don't!
02-22-2022, 04:11 PM | #11 |
Ah, mistook DLC for DIC. Now that makes sense although I wouldn't touch the DLC/OBD2 port wiring. Just too much going on thru there. It's finicky enough with devices that are made to be plugged into it let alone tapping/splicing into one of its wires. Appreciate the feedback but I'll go with an add-a-fuse extension into fuse2. Thanks again.
02-22-2022, 05:58 PM | #12 | |
02-22-2022, 06:11 PM | #13 |
^^^I agree with 1JEWLDSSRS^^^. Much appreciated!
02-23-2022, 06:02 AM | #14 | |
