Vararam
Old 06-06-2018, 09:28 AM   #1
stick1975
Drives: 2015 2SS 1LE Blue ray metallic
1LE Suede shift knob cleaning
Hi all, I joined the forum to share something I learned about the suede leather shift knob on the 1LE. Mine was super dirty and gummed up. After trying quite a few cleaners and brushes with no success I did some internet searches and found one person recommending Dawn dishwashing liquid. I was going to buy a new shifter anyways so I popped it off and tried it. My shifter looks brand new now. Before you buy expensive suede cleaners or a new shift knob, try dawn and water. Work it into a lather and then rinse.
stick1975 is offline   Reply With Quote
Old 06-06-2018, 10:00 AM   #2
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
Will try this, only used water and a microfibre cloth before.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 06-06-2018, 10:11 AM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Yep! Oils from your hand make the suede look rough and matted down. Anything that will remove the oils out of it will make it look brand new.
I keep a suede brush in my glovebox, and actually do brush out my shifter and wheel every week or 2, and I use Adam's upholstery cleaner when it gets beyond brushing.
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 06-06-2018, 11:18 AM   #4
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Good to know, thanks for the tip!
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 06-06-2018, 11:39 AM   #5
metrogdor22
Drives: 2013 2SS M6
Can you share a little more about the process? Is it a light scrub with a brush, or do you remove everything and soak it in soapy water?
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
metrogdor22 is offline   Reply With Quote
Old 06-06-2018, 12:03 PM   #6
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
This is what I use, works great. Hit the wheel and shifter once a week or so. Keep it in the door pocket and use it while waiting at stop lights, drive thru's, or to pick someone up.
Matty Ice is offline   Reply With Quote
Old 06-06-2018, 12:54 PM   #7
ChibiBlackSheep
Brush out as much dust as you can, then just spray cleaner on a microfiber, and wipe it down if it's not too matted.
If your shifter has some bad spots on it, looks really shiny and flat, I would remove it and run under water and use soap directly. Then hang to let it naturally dry.
Old 06-06-2018, 08:36 PM   #8
Tyestick
Tyestick's Avatar
Drives: 19’ Camaro SS 1LE
I use ‘Sonax Alcantara cleaner’, along with a interior detail brush.
I use the brush to knock any dust or grime from the shifter and steering wheel, then apply the Somax cleaner directly to the surface that I’m cleaning.
Otherwise, just follow the directions on the back of the cleaning product you’re using, and you’ll be good to go!
Tyestick is offline   Reply With Quote
Old 06-07-2018, 09:19 AM   #9
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
My wife likes it when I keep my knob clean.
gajagfan is offline   Reply With Quote
Old 06-07-2018, 01:13 PM   #10
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
Right into the gutter this thread went. C5 never disappoints.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 06-07-2018, 02:53 PM   #11
gajagfan
gajagfan's Avatar
I managed good self control yesterday, but I could not today! Sorry Billy!
Old 06-07-2018, 03:10 PM   #12
vinman
The BBOMG fill-in husband
vinman's Avatar
Drives: 2015 2SS/RS 1LE AKA V1LE
Wash them dick beaters!
UPSTATE C5 MEMBER
vinman is offline   Reply With Quote
Old 06-07-2018, 03:11 PM   #13
vinman
vinman's Avatar
I've done this for a few years now on the suede, just a few drops of dawn and hot water followed by a clean wet microfiber behind it then a dry one
UPSTATE C5 MEMBER
Old 06-07-2018, 09:38 PM   #14
JoeyBagOfDonutz
Drives: 2014 1LE
I was debating on removing the shift knob and cleaning it in the sink with dawn and water. Is soaking it a bad idea?
JoeyBagOfDonutz is offline   Reply With Quote
