Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
Old 03-12-2021, 03:56 AM   #1
DirectInjection
Drives: Chevrolet Camaro
Exclamation A10 subtle whine
Whenever I accelerate I hear a subtle whine by the transmission area while inside the car. I’m new to this transmission and I wanted to know if this is normal with all the A10s? My car is a 2021 SS and has 580 miles so far. Thanks in advance.
DirectInjection is offline   Reply With Quote
Old 03-12-2021, 10:18 AM   #2
Invertalon
Drives: 2021 2SS
Yep, this is normal. Mine also has a faint 'whine' at times under light acceleration. Almost sound like a HVAC blower or something, but it doesn't really sound bad, per-say. It's hard to describe, but it is a faint whine noise. But again, only under light acceleration... It goes away otherwise.
When I did research about the issue, found many people with the same thing. A few took the car to the dealer to be told it was normal and no issue.
I can't recall the last time I heard it, to be honest. Either I have tuned it out or it went away on it's own with more mileage. I will have to pay attention again next time I go out for a drive.
Invertalon is offline   Reply With Quote
Old 03-12-2021, 10:25 AM   #3
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Yes, this was discussed here a few years ago, the A10 has this characteristic whine that some notice more than others.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 03-13-2021, 05:50 PM   #4
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
The whine is there in 1,2,3,4,5,6. Pop it into 7th gear which is 1 to 1 and no more whine 7, 8, 9, 10
lt4camaro is offline   Reply With Quote
Old 03-14-2021, 12:16 PM   #5
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
The A10 has more than one planetary gear sets it uses to provide the different ratios. The gear sets are probably what is making the whine.
The teeth on the gears are cut at an angle and that angle is probably straight enough to make them robust enough to handle the torque input, but yet at such an angle not to be to loud.
Does anyone remember the Muncie M22 Rock Crusher? It whines like a grain truck transmission.
Same cause, the angle the gears are cut.
The sound of strength.
overdriv is offline   Reply With Quote
Old 05-26-2023, 05:22 PM   #6
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Anyone ever figure out this "whine" noise or have any problems? This guy says one of the problems with the 10L80 is the idler gear fails and causes a "whine"
Dynamical is offline   Reply With Quote
Old 09-05-2023, 07:49 PM   #7
MRREVINTO7
Drives: 14 1Le --14 chevy ss sedan 07shelby
great mine is a 23 LT1 2 days old at 137 miles has a slight whine but when i down shift it 2nd slowing down like 28mph then 1st it sounds like straight cut gears on a centrifigul blower is this normal ...its definately not the rear ...I wonder if its because 1st and second gear are just so low of a ratio ..anyway the problem is really when down shifting ..even in 3rd gear i dont hear it just 1st and 2nd..
MRREVINTO7 is offline   Reply With Quote
Old 09-05-2023, 08:26 PM   #8
Kamero6
Drives: 6th Gen LT1
Whine is 4-5-6. Is that gear set that has a planetary or something.
1-2-3 has normal transmission whine IMO
Kamero6 is offline   Reply With Quote
Old 10-23-2023, 08:14 AM   #9
KYVOM1LE
KYVOM1LE's Avatar
Drives: 2023 2SS 1LE
Yday while taking a cruise through a National Park, I heard a "chirping" sound when I slightly accelerated while going around 45-50 mph. I first thought it was birds I was passing along the route but wife also noticed and then i could replicate when I slightly got into the gas.
Am thinking it has to do with the gears downshifting. Anyone else notice this?
KYVOM1LE is offline   Reply With Quote
Old 10-23-2023, 08:29 AM   #10
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Yeah, from my tires
...but seriously as a resident "long time" A10 owner, the trans does emit a subtle whine at idle but it's quiet and often drowned out by the engine/supercharger noises. At least it did when new, I haven't noticed it in years. No noises when accelerating or shifting but it has the abrupt clutch closure on the 3->4 shift when cold (common in 2017's).
Gunkk is offline   Reply With Quote
Old 10-24-2023, 08:08 AM   #11
KYVOM1LE
KYVOM1LE's Avatar
Yes, agree the Chriping tire noise...But my A10 transmission is for the 2SS 1LE model. Could be different than the ZL1. i don't have a lot of history with the 10 speed so my knowledge is lacking. Tks
Old 11-21-2023, 03:06 PM   #12
gen6_1ss
gen6_1ss's Avatar
Drives: 2023 Sharkskin Metallic 1LE
23 1SS 1Le, Mine is doing the same whine noise. Took it to the dealer and they said the noise is coming from the front of the trans. Got an appointment to have the transmission specialist look at it, said it could take a week to fix.
gen6_1ss is offline   Reply With Quote
Old 12-01-2023, 11:47 PM   #13
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
Mine was a bit loud with the whine when I first got it, now it has 1500 miles on it and the whine sound has decreased a lot but there is still some sound. I'm guessing it is normal whine.
24 LT1 M6 Sharkskin Metallic
havelegs is offline   Reply With Quote
Old 12-08-2023, 02:40 PM   #14
gen6_1ss
gen6_1ss's Avatar
Got the car checked out again at the dealer. After having the transmission specialist look at it, he stated that it is a normal sound. He also told me I have a 60k warranty on it so just drive the shit out of it. I guess I'll have to live with it.
