AWE Tuning
Old 02-10-2019, 06:47 PM   #1
Bytor62
Drives: 2019 Camaro 2SS 1LE
Sunroof no longer available on 1LE?
New here. I went and test drove a 2019 2SS 1LE yesterday that was equipped with the sunroof. We went in to try and place an order and when the salesman added the sunroof, it deleted the 1LE package. Did GM eliminate the sunroof mid-year on the 1LE? Strange as they had 2 2019 SS 1LE's on the lot with the sunroof.
Bytor62 is offline   Reply With Quote
Old 02-10-2019, 07:52 PM   #2
Chevmaro
Chevmaro's Avatar
Drives: 2019 SS 1LE
Not sure but sunroofs add weight and decrease structural rigidity-neither are good for performance. 1LE is all about performance...
Chevmaro is offline   Reply With Quote
Old 02-10-2019, 07:55 PM   #3
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
If you have any thoughts of tracking it make sure you fit with a helmet on..
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 02-10-2019, 10:35 PM   #4
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
This has already been discussed. No, it doesn't decrease rigidity to any appreciable extent, the middle of the roof does not carry the majority of the load, it's not relevant. It's only a few lbs more, it's fairly inconsequential.
IMO, it does a lot to make the car seem more "open" inside, even if it does decease headroom a little. That said, either you want it or you don't. No worries.
the ZL1 can be ordered with a sunroof. The SS 1LE is essentially the ZL1 minus the engine.
Don't tell me you can't track a ZL1.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 02-11-2019, 07:59 AM   #5
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/22 Colorado TB/69 Chevelle
It's still available on 2SS w/1LE. Your dealer will need to submit the order using Quick Order. When using the normal "Configure a New Vehicle" build, it will force A1Y off of the order if you select sunroof. With Quick Order, it will accept it.
GearheadSS is offline   Reply With Quote
Old 02-11-2019, 09:20 AM   #6
Bytor62
Thanks! He's supposed to call me back today, if he hasn't figured it out I'll have to let him know.
Old 02-11-2019, 09:35 AM   #7
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
1SS 1LE = No sunroof
2SS 1LE = Sunroof available.
'18 1SS 1LE Black, PDR
Old 02-11-2019, 11:06 AM   #8
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
you dont want one trust me
Old 02-11-2019, 12:12 PM   #9
karmatourer
STD free
karmatourer's Avatar
Drives: 2018 Bright Yellow LGX M6 RS NPP
Which has nothing to do with this thread.
karmatourer is offline   Reply With Quote
Old 02-11-2019, 12:14 PM   #10
karmatourer
STD free
OK,tell us why we shouldn't trust you.
Old 02-11-2019, 12:21 PM   #11
kropscamaro16
it ruins the roof lines of the car and if you actually track the car with a sunroof the body flex can actually break it
my buddy had a cobalt ss with a sunroof and tracked his every once or so and broke it about 3 times in 5 years not fun especially if they dont cover it and also less headroom for a helmet
Old 02-11-2019, 12:41 PM   #12
Bytor62
I'm 6'5" and coming from a C6 Corvette. I'm used to tilting my head with a helmet on. I only took it to the drag strip a couple times.
I will honestly never track the car. But I did enjoy cruising the backroads with the top off in the Vette, wanted to get close to that in the Camaro.
Old 02-11-2019, 12:43 PM   #13
JamesNoBrakes
Drives: 2SS 1LE
And if this thread was about the Cobalt, that would make sense.
2018 2SS 1LE
2023 Colorado ZR2
Old 02-11-2019, 12:48 PM   #14
GearheadSS
GearheadSS's Avatar
Gen 6 Camaro has much more structural rigidity than a Cobalt. No comparison at all. Helmet clearance is definitely a concern for taller drivers though.
