09-04-2023, 03:24 PM | #1 |
Drives: 2018 ZL1 Join Date: Apr 2017
New Owner CEL
Hey everyone,
Just picked up a 2018 ZL1. Prior owner did a muffler delete and a secondary cat delete. The vehicle has giving a p2099 and p0430 code. What would be the best way to get this taken care of? |
09-04-2023, 04:55 PM | #2 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Start woth the easy stuff. Check for an intake leak and passenger side exhaust leak. If not that, try the rear O2 sensor on bank 2 (passenger side). Could be dirty MAF or malfunctioning cat, but my money is on exhaust leak or replace rear o2 on that side.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
09-04-2023, 09:17 PM | #3 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
You probably have an exhaust leak on the bank 2 straight pipe that was welded close in proximity to the sensor 2 O2 sensor and the owner before you probably didn't use NPP bypass modules. Hence your codes (I am assuming that's what the 2099 code is, without referring to my code chart).
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
09-05-2023, 07:22 AM | #4 |
fo'shizZL1
No, p2099 is still post cat stuff. Likely an exhaust leak or bad o2
09-05-2023, 07:48 AM | #5 |
fix the exhaust leak...likely at the spot where the secondary cats were deleted and didn't get properly welded on the top side of the pipe.
2016 NFG 1SS A8
09-05-2023, 10:25 AM | #6 |
Ah. Okay got it. Good to know. Lol.
737 HP/ 779 TQ |
2018 zl1, cel, p0430, p2099 |
