04-10-2022, 11:19 AM | #1 |
Drives: 20 ZL1 m6 Join Date: Apr 2022
P2096 code please help
I have a 2020 zl1 catless tuned on flex fuel and I started getting this code after letting the car sit for awhile I thought maybe a o2 sensor was acting up so I switched them to see if the code would then show on bank 2. The code has stayed off for over a month and multiple drag strip trips but last night Decided to come back on. Everything seems to run great actually got a new personal best at the track last night and then after airing up at the gas station it popped up again. It seems fine it’s always had a little stumble here and there at idle but nothing crazy and my intercepted gauge doesn’t show any misfires when I check. Has anybody else dealt with this or have something I should be looking at? Would a catch can help possibly I’m just lost because the car runs great? Thank you!
Chevy Camaro P2096: Post Catalyst Fuel Trim System → Too Lean → Bank 1 Last edited by Ruthlesszl1; 04-10-2022 at 11:23 AM. Reason: Adding code description |
04-11-2022, 01:43 PM | #2 |
This indicates a lean condition. Hook up a scan tool and check fuel trims.
If trims are OK check for air leaks where you did the cat delete. This code specifically refers to a lean condition at the secondary O2 sensor. Since this code "comes and goes," I would bet air leak. |
04-12-2022, 05:46 PM | #3 | |
04-13-2022, 10:09 AM | #4 |
Maybe try wrapping some of that exhaust tape around the cat delete joints in case there is a leak you can't see. That stuff is cheap enough.
04-13-2022, 09:56 PM | #5 |
I have the arh 2 in long system it has one of the almost like ball socket joints where it connects
04-13-2022, 10:02 PM | #6 |
Also my interceptor is getting some misfires more so when idling across all cylinders haven’t seen it go above 6 though is this normal
04-14-2022, 11:28 AM | #7 | |
https://www.camaro6.com/forums/showthread.php?t=589791 |
04-14-2022, 06:10 PM | #8 | |
04-15-2022, 09:39 AM | #9 |
I have used this stuff on exhausts:
https://www.amazon.com/Permatex-8187...0002UEOPA?th=1 |
04-15-2022, 07:39 PM | #10 | |
04-15-2022, 09:17 PM | #11 |
Also I have the aero force interceptor gauge what am I looking for on the fuel trims I’ve never checked those before I mean I’ve looked I just don’t really get what I’m looking at but bank 1 is usually higher than bank 2 by a few numbers
cel, lean, p2096 |
