04-18-2021, 09:35 PM | #1 |
What does your Camaro weigh?
I was surprised to see the weight on my 2011 SS. I removed the feont and rear seats, seat belts, rear seat bracket, center console, rear side panels, everything from the trunk besides the battery. Rear curtain airbags, lots of interior plastics. Oil cooler, front swaybar, washer res, and some other little stuff.
I installed an Iron Dart block, a Supercharger kit, full exhaust. I think the bmr drag kit and anti roll bar and probably a wash with the stock stuff, and same for the strange front/rear coilovers. Smaller brakes in rear with 15s. She’s still a heafty girl! This is with just over 1/2 tank of fuel and me (185#) standing on the front axle scale. (Had to press the button). So some of that weight, might shift rearward, but still counts in the total. Cant ditch the AC yet... What does yours weight?
2011 Camaro SS---SOLD
04-18-2021, 09:36 PM | #2 |
Forgot to mention i obviously installed a single lighter racing seat, harness bar and 5 point harness.
04-18-2021, 10:59 PM | #3 |
With me in the car supercharged it weighed 4140. I weigh 200. Now my car weighs 3950 or so NA with a few things removed. Me in the car.
04-19-2021, 03:23 AM | #4 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Had mine weighed after a supercharger install and removal of factory exhaust system (replaced with long tubes and single hi-flow cats. Came in at 1799kg /3966 lbs not including me at a svelte 80kg / 176 lbs. Puts my car at just about 403hp/ton (which is far more important!)
04-19-2021, 05:24 AM | #5 |
Mine was at 3900 without me in it before the supercharger install
04-19-2021, 06:45 AM | #6 |
4250 with me and 1/2 tank of fuel.
04-19-2021, 11:03 AM | #7 |
Ok, so I guess it's fairly decent considering the iron block and sc weight. the zl1 diff should add some weight to the rear.
04-19-2021, 01:41 PM | #8 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
3980 without me in it.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
04-20-2021, 06:30 PM | #9 |
Drives: 2015 1LE Join Date: Oct 2015
2015 1LE, 3720 without me in it.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
04-23-2021, 04:23 PM | #10 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
My 2010 auto with no passenger or rear seats and the trunk bare weighed 3640 without me. I need a drag pack so I can get into the 3500's. Im N/A though.
04-24-2021, 10:33 AM | #11 |
Drives: 2010 SS L99 Join Date: Sep 2018
3,550 lbs without me in it, 1/3 tank of fuel, I am 220
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
04-24-2021, 12:14 PM | #12 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
4175 with me, 1/2 tank and supercharger system. Stock interior.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
04-26-2021, 12:07 PM | #13 |
That's pretty good. What did you remove to get that light?
04-28-2021, 05:07 PM | #14 |
Thanks!
At the track I run open headers, 2" TSPs, so all the exhaust Front crash bar Skinnies up front all 4 bias ply tires passenger and rear seats out front sway bar removed wiper fluid reservoir removed all the trunk lining and the stuff that comes in there floor mats When its time for new brakes I'll go Aerospace and that will shave some good rotational mass.
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 04-29-2021 at 06:55 AM. |
