dave@hennessey
Old 04-18-2021, 09:35 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
What does your Camaro weigh?
I was surprised to see the weight on my 2011 SS. I removed the feont and rear seats, seat belts, rear seat bracket, center console, rear side panels, everything from the trunk besides the battery. Rear curtain airbags, lots of interior plastics. Oil cooler, front swaybar, washer res, and some other little stuff.
I installed an Iron Dart block, a Supercharger kit, full exhaust. I think the bmr drag kit and anti roll bar and probably a wash with the stock stuff, and same for the strange front/rear coilovers. Smaller brakes in rear with 15s.
She’s still a heafty girl! This is with just over 1/2 tank of fuel and me (185#) standing on the front axle scale. (Had to press the button). So some of that weight, might shift rearward, but still counts in the total.
Cant ditch the AC yet...
What does yours weight?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-18-2021, 09:36 PM   #2
eLeSthree
Forgot to mention i obviously installed a single lighter racing seat, harness bar and 5 point harness.
1158whp 1017wtq.
630whp 658wtq
Old 04-18-2021, 10:59 PM   #3
Bo White
Bo White's Avatar
With me in the car supercharged it weighed 4140. I weigh 200. Now my car weighs 3950 or so NA with a few things removed. Me in the car.
Totalled:
Old 04-19-2021, 03:23 AM   #4
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
Had mine weighed after a supercharger install and removal of factory exhaust system (replaced with long tubes and single hi-flow cats. Came in at 1799kg /3966 lbs not including me at a svelte 80kg / 176 lbs. Puts my car at just about 403hp/ton (which is far more important!)
Yellow 1 is offline   Reply With Quote
Old 04-19-2021, 05:24 AM   #5
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Mine was at 3900 without me in it before the supercharger install
gunchamp is offline   Reply With Quote
Old 04-19-2021, 06:45 AM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
4250 with me and 1/2 tank of fuel.
Old 04-19-2021, 11:03 AM   #7
eLeSthree
Ok, so I guess it's fairly decent considering the iron block and sc weight. the zl1 diff should add some weight to the rear.
1158whp 1017wtq.
630whp 658wtq
Old 04-19-2021, 01:41 PM   #8
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
3980 without me in it.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 04-20-2021, 06:30 PM   #9
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
2015 1LE, 3720 without me in it.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 04-23-2021, 04:23 PM   #10
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
My 2010 auto with no passenger or rear seats and the trunk bare weighed 3640 without me. I need a drag pack so I can get into the 3500's. Im N/A though.
SSkat is offline   Reply With Quote
Old 04-24-2021, 10:33 AM   #11
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
3,550 lbs without me in it, 1/3 tank of fuel, I am 220
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 04-24-2021, 12:14 PM   #12
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
4175 with me, 1/2 tank and supercharger system. Stock interior.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 04-26-2021, 12:07 PM   #13
eLeSthree
That's pretty good. What did you remove to get that light?
1158whp 1017wtq.
630whp 658wtq
Old 04-28-2021, 05:07 PM   #14
Chris49066SS
Drives: 2010 SS L99
Thanks!
At the track I run open headers, 2" TSPs, so all the exhaust
Front crash bar
Skinnies up front
all 4 bias ply tires
passenger and rear seats out
front sway bar removed
wiper fluid reservoir removed
all the trunk lining and the stuff that comes in there
floor mats
When its time for new brakes I'll go Aerospace and that will shave some good rotational mass.
