06-04-2023, 05:02 PM | #1 |
Drives: 23 Camaro ZL1 Join Date: Mar 2023
23 Camaro ZL1 Jack Pads
Anyone have any suggestions for jack pads for my 23 Camaro ZL?
06-04-2023, 05:14 PM | #2 | |
https://zl1addons.com/collections/ca...lton-lift-pads
'20 ZL1 1LE A10,
06-04-2023, 05:42 PM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
ZL1 add-ons as mentioned. Tried and true and gets the job done.
06-04-2023, 08:13 PM | #4 |
Drives: Sharkskin Metallic ZL1 Join Date: Mar 2023
No issues with the ones I bought off of Amazon for 30 some bucks. I did get myself longer set screws so I was using all of the the threaded part of the hole, even when tightened up.
06-04-2023, 08:39 PM | #5 | |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
https://a.co/d/2xGo8EX
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED 2004 CTS-V SOLD 2005 CTS-V SOLD 2006 300C SRT-8 SOLD 2006 300C SRT-8 SOLD 2010 CTS-V SOLD 2012 CTS-V coupe SOLD 2013 ZL1 vert SOLD 2016 Callaway Z06 SOLD 2019 Z06 SOLD "I lived my life by one motto.......mottos are for losers" cvp33 |
06-05-2023, 03:38 AM | #6 |
Drives: 2023 ZL1 - 1969 SS396 Join Date: Sep 2022
Smart idea utilizing max threads for set-screw strength. I also purchased a set through ZL1 Addons. When I laid down to do the install, I saw what a good move it is to install these. There is utterly no where to place a floor jack that would not cause damage IMO.
Brett.....
2023 Code ZL1 1AL37 - Track Pack PPF
1969 Code X66 SS396 - RS Conversion - Holley Terminator TB w/ HP ECU EFI - TKO600 - 3.73 Posi. |
06-05-2023, 06:35 AM | #7 |
I concur the set for ~$30 on Amazon.
06-05-2023, 07:38 AM | #8 |
Drives: 2022 Camaro ZL1 Join Date: Dec 2021
I got the 30 dollar ones off ebay. The set screws tips seemed too "sharp" or "pointy" so I filed the tips down a bit . They fit great and have been utilized several times with no problem.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10 2020 Ford Mustang Shelby GT500 2020 Genesis G90 Ultimate 2019 Mercedes-Benz SL450 2017 Corvette Grand Sport A8 2016 Hyundai Equus Ultimate 1971 Datsun 240Z |
06-05-2023, 08:47 AM | #9 |
NYTMARE23
Drives: Black 2023 Chevrolet ZL1 A10 Join Date: Oct 2022
3 stupid questions about the jack pads:
1. Can I install them with the car(tires) sitting on the ground or does it(the car)need to be jacked up a bit? 2. Once they are put on, do you guys just leave them on or do you only put them on when needed to jack the car up? 3. Where EXACTLY do each of the 4 of them go on underneath the car? Thanks ahead of time!!
2023 A10 ZL1 "NYTMARE"
06-05-2023, 09:38 AM | #10 |
1) Yes. You can install them without the car needing to be lifted.
2) With the ZL1 add-ons and similar variants, you leave them on. One type is magnetic and the other type has a set screw to hold it in place. I have the set screw version and never have taken them off or had any fall off. 3) There are 2 lift points on each side. Best way to tell you is to look under the car and you'll see a very obvious gap in the side skirt. There are 2 pictures in this thread that show where you should jack the car up: https://www.camaro6.com/forums/showthread.php?t=548253 |
06-05-2023, 09:59 AM | #11 | |
NYTMARE23
06-09-2023, 07:40 AM | #12 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
ZL1 Addons Stealth lift pads
https://youtu.be/SmFUekbDQFQ with the thumbnail Sent from my iPhone using Tapatalk Pro
06-09-2023, 09:09 AM | #13 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
06-10-2023, 04:27 PM | #14 |
I ordered the ZL1 Adonis jack pads…I’ll let you know when they arrive
Thank you |
