Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 04-09-2019, 10:09 PM   #183
Bytor62
Drives: 2019 Camaro 2SS 1LE
I have a 2SS 1LE on order (supposed to be here next week) and have been following this thread. The info below is from the 2019 Camaro Track Preparation Manual. Since the manual specifically mentions Valvoline SynPower, why not use it instead of the Mobil 1? I was going to go to NAPA and get the deal they have now on the Valvoline. Curious as to why spend the extra dollars if the Valvoline is approved.
"Engine Oil
(0W-40 or 5W-40 that meets the dexos2 specification. If this oil is
not available, you can use Valvoline® SynPower MST 5W-40 or
Mobil 1® 15-W-50 engine oil)"
Bytor62 is offline   Reply With Quote
Old 04-09-2019, 11:25 PM   #184
TrackClub
TrackClub's Avatar
Drives: 2020 SS 1LE (previous: 2017 SS 1LE)
"Engine Oil
Zero reason not to use Valvoline. As a mtter of fact it will provide better protection on warm summer start ups.
Save your money
TrackClub is offline   Reply With Quote
Old 04-10-2019, 01:07 AM   #185
jmhinkle
jmhinkle's Avatar
Drives: 2018 2SS Vert
Save your money
I don't think you understand how oil works. The MST will not provide better protecting on any startups as the mobil covers a wider range. Also, read some tests on the MST on Bitog. It's not well liked and didn't hold up well. There are better oils that don't have the BS dexos label if you think MST is decent for the car.
jmhinkle is offline   Reply With Quote
Old 04-10-2019, 09:27 AM   #186
TrackClub
TrackClub's Avatar
If you dont understand a benefit of a higher winter start up rating in summer time, then you dont understand how oil works.
Note the car's manual recomments 3 oil grades as authorized for track use: 0w40, 5w40 and 15w50! The last one for track use only and the only oil approved for zl1 1le track use. Please note the 15w cold start up rating here and ponder it for a while.
As far as pro analysis of Valvoline MST...a few have been published here by members after several track days and received top quality results. Personally i dont care if MST were to be "not well liked" by some Bitog blog users named "tomato", or "molycool"...etc.
Dexos2 is not a "BS label". It is what maintains our car's warranty including unrestricted track duty. That's a BIG DEAL to anyone that tracks their cars. Moreover, the purpose of GM's Dexos standard is no different than licensing standards by other OEM like Porsche, BMW, Ferrari, Mercedes, etc.
Cheers!
Old 04-10-2019, 01:36 PM   #187
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Originally Posted by Z0Tex View Post
Mobil 1. This particular 15W-50 is available at most Walmarts.
https://mobiloil.com/en/viscosity/15w-50
Brother, There isn't even anything close to 15w50 in Mobil 1 at my Wal-Mart.
The Specialist is offline   Reply With Quote
Old 04-10-2019, 02:42 PM   #188
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
"Engine Oil
So you just spent ~$45k on a sports car, get the best oil + filter, which is M1 0w40 ESP and WIX XP.
There are plenty of reasons M1 ESP is superior, if you don't want to learn all about oil just trust the LT1 engineers and use it.
DaveC113 is online now   Reply With Quote
Old 04-10-2019, 02:45 PM   #189
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Yup! People bitch about the cost of the most important thing you can do for your car (oil changes) yet spend hundreds and even thousands on silly cosmetic items just to look good.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 04-10-2019, 05:00 PM   #190
Bytor62
Damn dude, I was just asking a question. Just to make sure, what TP do you use? I use Charmin!
Old 04-10-2019, 05:04 PM   #191
Bytor62
And I wasn't bitching about price. If it's GM approved, I wanted to know why not to use the Valvoline. Of course I get no help from you or DaveC113.
Old 04-10-2019, 05:15 PM   #192
DaveC113
DaveC113's Avatar
Lol, Ohhh... I'm soooo sorrrry. Are you going to be ok?
It's not a super-simple question to answer, I can say it's low SAPS but then I have to explain that, etc... If you're really interested check out Bob is the oil guy forum, here and vette forums about the M1 ESP oil and why it's different/better.
Or, if you don't want to learn and simply take someone else's advice, I'd recommend taking GM's advice and ignore everyone else, and run the M1 0w40 ESP.
Old 04-10-2019, 05:29 PM   #193
TrackClub
TrackClub's Avatar
Charmin is great! Ass fully approved
But seriously: no GM documentation (nor trusty GM engineers) specifically recommend Mobil 1 ANYWHERE.
Not in the Camaro manual and not in the Corvette manual. All that is required is that oil meets Dexos2 GM standard and be of an appropriate grade. And btw Valvoline MST does meet Dexos2 now.
We are all free to use whatever we deem best, based on whatever criteria we choose to apply.
Personally, i go by what official documentation lists as approved, as i am damn sure GM engineers had direct input to all the specs there. Therefore, if they thought it wasnt necessary to specifically list Mobil 1 as a preferred oil, we have other choices - as listed - being equally good. But, that's my logic for my car. And anyone should be free to use their own logic for their own car. Cheers!
Old 04-10-2019, 05:36 PM   #194
TrackClub
TrackClub's Avatar
Be careful sir! M1 0w40 esp has been around for a very long time and is not forward compatible to m1 0w40 est DEXOS2, so please dont forget that little bit as it matters a whole lot. Would you have any sources you can share regrding GM's formal advice to use M1 oil? Serious question, as i have not been able to find anything specific from GM. Clearly if such info existed it would have a bearing on my choices. Thanks!
Old 04-10-2019, 05:44 PM   #195
Bytor62
Classy! I will leave this thread now. Enjoy!
Old 04-10-2019, 05:45 PM   #196
DaveC113
DaveC113's Avatar
Sorry man, you're wrong, the ESP version of M1 0w40 is brand new DEXOS 2 certified oil, you need to do some more research as your info is badly out of date and your previous advice to use Valvoline is bad advice.
There ARE specific recs from GM engineers posted here and on vette forums btw.
Unfortunately I don't have the threads bookmarked, but please...
