08-14-2022, 03:11 AM | #1 |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
2020 oil pump failure
Hi guys,
I saw this topic and share… maybe the owner is on this forum… I thought a lot of us supposed that it was only a 2017-2018 problem… |
08-14-2022, 05:35 AM | #2 |
Just because a 2020 has an oil pump failure doesn't mean it's a problem like it was in 2017-2018. There will always be some defects or failures in ANY year, it's when it's an unusually high percentage relative to unit sales that it becomes an issue. Overwhelmingly, 2017 and 2018 are typically reported with this issue, that does not mean there will not be a small number in 2019, 2020, 2021, 2022, etc. that won't have a defect.
08-14-2022, 07:46 AM | #3 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
I think we can never completely understand the extent of the problem unless we have exact numbers from GM. We have some idea, but our population is limited to those that use this website. The issue is probably more widespread. I wish GM would go further than the TSB regarding the spring. If other models used the same pump and there was a defect, it’s likely they are having failures not reported here.
08-14-2022, 07:50 AM | #4 | |
ZL1 Driver
08-14-2022, 08:05 AM | #5 | ||
ZL1 Driver
https://www.camaro6.com/forums/showthread.php?t=532479 |
08-14-2022, 09:45 AM | #6 | |
08-14-2022, 09:52 AM | #7 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
I've read and read on these oil pump failures and warm up the machine completely each time I get in.
IG - @zl1_will
2022 zl1 740hp / 730tq stolen 2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms |
08-14-2022, 09:53 AM | #8 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
08-14-2022, 12:38 PM | #9 |
Drives: 2022 ZL1 1LE Join Date: Sep 2015
Hi all,
This issue was the biggest reason I sold my '18 ZLE. I even had a really great 120K 10 year B to B extended warranty, but I did not like the stress feeling all the time that a fun day driving to the mountains could end up in a blown oil pump, leaving me stranded. The new '22 ZLE has much better oil pressure and seems to be running as strong as my '18 did. I even used the newer 0W 40 Mobile 1 in the "18, but it still never had as good oil pressure as the new '22. I don't track my cars, and they always got early fluid break in changes and regular oil changes at no more than 4k miles. It is true that owners will never know what, if any, changes GM and/or Melling did to these oil pumps. I pray my new '22 will not give me the same stress that the '18 did about the oil pressure/pump failure. It certainly is running at a much better (IMO) oil pressure than the '18 did. I didn't get the extended warranty this time, as I am planning on purchasing a 2025 ZO6....after we see how those motors hold up after a few years in service. I really love my ZLE and will enjoy it to the fullest until 2025. If it starts to act up before then, I will trade it and get something else. I bet someday in the future some GM exec will let it out that they knew about the oil pump issue but did nothing to actually fix it. It is most unfortunate that GM did such a great job on these ZL1's, but 'cheaped out' on fixing a super important part of such a high output engine. JMO, Take care, JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
08-14-2022, 01:13 PM | #10 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
08-14-2022, 01:32 PM | #11 |
ZL1 Driver
Sorry, thought OP had a failure
08-14-2022, 01:39 PM | #12 | |
ZL1 Driver
Did your 18 have an oil pump failure? My cold idle is 36-42 Warm 29-32 Acceleration cold 40-60 Warm 30-50 WOT cold 60-70 Warm 50-70 Thank you for your input |
08-14-2022, 03:15 PM | #13 | |
… lol… do you know a lot of car series with such a problem ?? Un That’s not like if it was something isolated… but… you’re right on this fact .. this is not a proof But there is a presumption beam that make me think it’s the same as the others 2017 2018 problem… |
08-14-2022, 03:34 PM | #14 |
Very presumptuous. The data thus far doesn't support your theory.
