08-29-2021, 06:34 AM | #15 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
I have the CSP headers got them over the summer and no issues. Sucks you got a bad one, technically it’s a stainless works problem…. but I’d contact CSP and see what they would do. However looks like you spent some coin and had a nice coating put on it. That might make things a little more difficult.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-29-2021, 07:15 AM | #16 | |
08-29-2021, 09:01 AM | #17 |
You could just block sand the flange with a long sanding block and some 80 then 120 grit. Then check it with a straight edge.
It shouldn't have come from CSP like that but you should be able to correct it pretty quickly. |
08-29-2021, 09:50 AM | #18 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
I was wondering how long it would take to figure out, a search button on past post go's a long way.
08-29-2021, 10:25 AM | #19 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
My BBK's were pretty bad also. The machine shop hat to shave off quite a bit to make them straight.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
08-29-2021, 04:52 PM | #20 |
Drives: HBM ZLE Join Date: Aug 2017
09-01-2021, 08:21 AM | #21 | |
Drives: 2018 Camaro ZL1 A10 Join Date: Nov 2018
We had a bad batch come in and stopped shipment due to an issue with a primary not fitting properly and have been waiting for them to be repaired - but with material shortage it's been a delay. Next batch is due in a few weeks, just waiting on the 1700 HP cats to come in. Anyone who may have run into that issue, as it's just really close which may or may not hit, can have theirs fixed at no cost as well. This flange issue seems separate, but I will tell you it's covered. Unfortunately, and not to make excuses, but rather give an explanation, manufacturers have had to train quite a bit of new people. I have addressed all these issues with them and their QC department letting it get by and am happy to report you can even go direct to Stainless Works to have your CSP header fixed if you don't want us to set it up. Please reach out to us if there are any issues. That way we can address them. Andrew |
09-01-2021, 08:56 AM | #22 | |
09-01-2021, 10:51 AM | #23 |
Bravo !
09-01-2021, 11:43 AM | #24 |
For what it's worth, I've only bought one Stainless Works product, a set of off-road pipes for my Hellcat, they didn't fit, looks like the jig was off and one of the pipes was touching my trans brace. Contacted Stainless Works about it and they told me they would investigate and get back to me. Weeks went by and nothing, I contacted them again and they told me they would correct the issue on future batches. I asked if I could send the pipes back for a replacements. I felt I was owed that for identifying a defect on their part. They never responded back. That was the last Stainless Works product I bought from them.
09-01-2021, 07:50 PM | #25 | |
09-02-2021, 06:32 AM | #26 |
Drives: 2019 ZL1 Join Date: Oct 2019
Buddy's set wasnt warped but the passenger side collector area barely rubs the aluminum crossbrace under throttle. Will take a picture next time we have it on a lift. Also melted the plastic on his steering shaft cover despite the Jet Hot coating. Wrapped it in DEI cool tape and wrapped the passenger side lower harness too to prevent issues.
09-02-2021, 07:47 AM | #27 | |
09-02-2021, 08:46 AM | #28 |
Drives: 2017 ZL1 A10 Join Date: Aug 2009
I have LG headers & they are leaking & touching the brace like crazy 🤪
I ordered a set of Dynatech 2" hoping they will fit great. Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
