Old 02-20-2023, 02:08 PM   #15
oldman14ss
Drives: 2014 1ss camaro
hey Bo, those gorilla welds? ugly as heck but stronger than he**.
oldman14ss is offline   Reply With Quote
Old 02-22-2023, 09:17 PM   #16
SS•209•California
Drives: SS Camaro
I’ll definitely be doing this mod real soon. i Need to replace my oil pump and would like to replace the oil pan gasket as well So I don’t run the chance of having a leak. Plus it would be a good idea to clean out oil pan and check the screen on the oil pump pick-up tube.
SS•209•California is offline   Reply With Quote
Old 03-29-2023, 07:12 PM   #17
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
to clear the steering rack- I just remove the motor mount bolts, jack the engine up an inch from underneath, then slip a couple of 3/4" wood shims between the motor mount and sub frame.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 04-02-2023, 09:10 PM   #18
Bo White
Bo White's Avatar
Yeah either way your unbolting something. I'm a chassis guy so lol
Totalled:
Old 06-29-2023, 07:09 PM   #19
EZE.Cervantes01
Drives: Chevrolet camaro
Hey, where can I order some for my car
EZE.Cervantes01 is offline   Reply With Quote
Old 06-29-2023, 07:15 PM   #20
EZE.Cervantes01
Where can I get a set of these flanges.
Old 06-30-2023, 09:20 AM   #21
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
CFD on this forum sells them.
While I'm at it, here's my install video.
https://youtu.be/2iqekORDMu8
FasNuf is offline   Reply With Quote
Old 07-02-2023, 09:54 AM   #22
jccrowe4902
Drives: 2011 camaro
CFD info
Does anyone have CFD contact info, looking to get a set of crossmember flanges?
jccrowe4902 is offline   Reply With Quote
Old 07-02-2023, 11:26 AM   #23
DavidH
DavidH's Avatar
Message member CFD on here for the brackets.
I got mine a few weeks ago, top notch guy.
https://www.camaro5.com/forums/member.php?u=25649
DavidH is offline   Reply With Quote
Old 07-02-2023, 11:48 AM   #24
jocamass
Drives: 2010 camaro ss
I love the group
Sent from my SM-N960U using Tapatalk
jocamass is offline   Reply With Quote
