Roto-Fab
Old 12-13-2021, 11:43 PM   #29
Bo White
Bo White's Avatar
Originally Posted by eLeSthree View Post
I ordered the holley 508-24 gasket, which is 105mm just in case. Same bolt pattern. hopefully it fits.
I was hoping my current Jegs fuel rails would work. Did you re-use the stock intake manifold bolts or buy the recommended bolts?
I'm about to tear apart the car and would like to have everything on hand. I'll probably have to redo the fuel lines though.
Correct. Overall it's about the same price as the Holley. The injectors are vertical so traditional rails won't work. Also the manifold is drilled for either the LS3 or tall injectors using the Edelbrock rails.
Totalled:
Old 12-14-2021, 04:00 PM   #30
eLeSthree
Drives: 2011 Camaro SS 6sp
You werent kidding about hammering it in. I filed it down and still beat the shit in. I just tapped and plugged the other side since i only needed one large source.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 05-10-2022, 03:29 PM   #31
Watts ss
Drives: 2013 camaro zl1 2012 camaro ss
Did anybody notice if it changed our TB opening location or angle very much?
I’m considering this intake for my FI 416ci build but don’t want to have to redo my inlet piping from s/c!
This intake looks to be making some great power, any figured out where it stops rpm hp gains and just maintains when applying 18/20+psi?
Watts ss is offline   Reply With Quote
Old 05-13-2022, 09:13 PM   #32
Bo White
Bo White's Avatar
Changes it a good bit.
Totalled:
