04-05-2021, 10:48 PM | #15 |
I'm in the middle of putting these on finally. Going to the dyno Sunday and I'll see for myself.
04-13-2021, 03:27 AM | #16 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
On a stock LS3 with headers janetty racing picked up 10 more numbers with 2” over 1 7/8”. That seems to be the general consensus. And as always bo will show us his results because he’s an apples to apples kind of guy! Just like with the 416 vs bottom end with the same cam.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
04-13-2021, 06:57 AM | #17 |
Thanx for reminding me. I picked up zero until after peak power. In the overrev it was 8rwhp 2" vs 1 7/8"
Don't know about bottom end changes because my stall absorbs everything pretty much below 5500rpm.
04-13-2021, 11:21 AM | #18 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Any pics of them installed? Any fitment issues?
603 h.p. 495 ft lbs tq. |
04-13-2021, 10:56 PM | #19 |
I just recently put BMR mounts on and had to loosen it up and shift the engine over a touch because they are slotted.
