AWE Tuning
Old 08-18-2019, 08:51 AM   #1
full*throttle*therapy
Drives: '18 RH ZL1 1LE
Why doesn't anyone sell just the rotors?
(not a new post topic I know, just want to see if anyone had fresh leads)
I thought one benefit of a 2 piece setup was being able to purchase just rotors? I'm in need of all 4 rotors already, and I've scoured the net for just rotors..and can't find them. Heck I can't even find any complete non-oem front sets.
The ZL1 has been out long enough where you would think someone would offer them.
..I know girodisc sells a setup, but you need buy a brand new 2 piece setup in order to use girodisc replacement blanks. This defeats the purpose.
full*throttle*therapy is offline   Reply With Quote
Old 08-18-2019, 10:45 AM   #2
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
there is a dude in the classified section selling all 4 of his originals. That is 1 option.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 08-18-2019, 12:55 PM   #3
Vigilante375
Drives: 2018 Camaro ZL1
Really? If you can find oem then why wouldn't someone sell non oem separately
Vigilante375 is offline   Reply With Quote
Old 08-18-2019, 01:41 PM   #4
I can't find OEM OR Non-OEM rotors anywhere.
Old 08-18-2019, 02:28 PM   #5
esm
esm's Avatar
Drives: 2019 ZL1
Front Rotors:
https://www.gmpartsdirect.com/oem-pa...rotor-84271643
When I ordered the front rotors the rear rotors were on back order. Bought non-GM rotors from Ken at KNS Brakes.
https://www.knsbrakes.com/c/car-seri...-+Single+Rotor
2019 Black ZL1 - A10
esm is offline   Reply With Quote
Old 08-18-2019, 02:49 PM   #6
Originally Posted by esm View Post
Front Rotors:
I don't need the hat, just the front rotors, no hats. They are a 2 piece assembly. Why bother with a 2 piece setup if you can't buy just one of the pieces?
Old 08-18-2019, 09:35 PM   #7
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
viurniel is offline   Reply With Quote
Old 08-18-2019, 10:09 PM   #8
SteveV
SteveV's Avatar
So, you are looking for just rotor rings, not whole rotors. In the parts catalog, the rotor, is both the hat and the ring.
You are apparently only looking for the rings.
Old 08-18-2019, 10:34 PM   #9
GrimReaperSS
Drives: 2001 Onyx Black/Ebony SS. 427/M6
The idea behind the 2 piece rotors in not servicability. Especially in a warranty situation, the manufacturer is not going to pay a tech time to take apart a rotor and re-assemble when they can pay far less time to just replace the whole thing. The aluminum hat is there for weight savings and quite possibly heat transfer away from the ring.
GrimReaperSS is offline   Reply With Quote
Old 08-18-2019, 11:25 PM   #10
RabbitZL1
https://www.camaro6.com/forums/showthread.php?t=492428
RabbitZL1 is offline   Reply With Quote
Old 08-19-2019, 02:11 AM   #11
RSFR
RSFR's Avatar
Drives: ZL1
Originally Posted by RabbitZL1 View Post
That's for the SS 1LE, which uses a different rotor size.
The brake situation for the ZL1 is crap, spent a while looking for something and eventually bought the Girodisc rotors.
RSFR is offline   Reply With Quote
Old 08-19-2019, 06:22 AM   #12
RabbitZL1
I myself have Z06 carbon front rotors and pads on my Zl1.
Last edited by RabbitZL1; 08-19-2019 at 06:57 AM. Reason: I’m a doof and put bad info
Old 08-19-2019, 06:42 AM   #13
RSFR
RSFR's Avatar
Drives: ZL1
Z06, Zl1, SS1LE are all the same. As you can see he ordered z06 rotors. I myself have Z06 carbon front rotors and pads on my Zl1. All the same.
The SS 1LE and Z06 are the same for iron rotors. I think they're both like 370mm front. The ZL1 and ZL1 1LE are different, they use 390mm front rotors. The Z07 (carbon ceramic) uses 394mm front rotors I believe. They don't all mix and match with each other.
Old 08-19-2019, 06:44 AM   #14
SteveV
SteveV's Avatar
Hey Rabbit, you just used carbon front rotors and swapped pads using the original ZL1 calipers?
If so, wow. What a great idea. Have you tracked your car with this setup? How is the feel?
