03-11-2023, 07:04 PM | #1 |
Drives: 2017 Nightfall Grey 2SS 6 Speed Join Date: Jan 2022
I think I broke the connector for my NPP exhaust?
On my 2017 SS my NPP valves have been non functioning.. I have 2 new NPP actuators that I am trying to install so I can use the exhaust valves again. The driver side one looks corroded and will not come unplugged. The connector separated into 2 different pieces when I was trying to unplug it (first photo). The passenger side valve came unplugged no problem (second photo). Am I doing something wrong? Is it possible to cut it off and put a new connector on?
03-12-2023, 07:53 AM | #2 |
Well, you didn't break the wires, so what you have will be usable, even if you have to use some tape/epoxy/silicone to hold the connector all together.
The corrosion is probably what's holding it in. Hopefully the contacts on the part you are reusing are salvageable. I would first try rocking it out with pliers. If stuck firm, I would file the oval ends of the female socket. That is on the actuator which you are replacing. File it enough so you can open it like a clam shell. Then hopefully you can free it off the corroded pins. If you can salvage it all you are going to have to waterproof what you reassemble. Silicone smeared all around it should do the trick. Just don't pile it on too much in case you have to remove it again. |
03-30-2023, 06:13 PM | #3 | |
dual mode exhaust, npp, npp exhaust defect |
