dave@hennessey
Old 01-06-2014, 07:35 PM   #1
The_Blur
Moderator
The_Blur's Avatar
Sway Bars by Company
If you are a vendor and do not see something listed, add it! I want this list to be comprehensive.
The format for this thread is as follows:
Sway Bar Company (First Year Valid*) Series (if present) Part Number
Front Bar (mm) tubular or solid
Rear Bar (mm) tubular or solid
*Kits with multiple years have kits available for suspensions starting each year. Keep in mind that 2010 and 2012 are the first years of new suspension components for Camaros. In other words, there are required upgrades to put a 2012 sway kit on a 2010 Camaro.
Please use this as a resource for choosing your sway bars.
Chevrolet Camaro SS ("FE4" 2012+ coupe)
23 solid
24 solid
Chevrolet Camaro 1LE (2013+)
27 solid
28 solid
Chevrolet Camaro ZL1 (2012+)
25 solid
28 solid
Chevrolet Camaro Z/28 (2014+)
25 solid
26 solid
Belltech (2010)
25 solid
BMR (2010) Xtreme
35 tubular
BMR (2010, 2012)
29 tubular
25 tubular
Eibach (2010)
29 solid
29 solid
Hellwig (2010)
32 tubular
25 tubular
Hotchkis (2010) Competition
32 tubular
35 tubular
Hotchkis (2010) Sport
32 tubular
25 tubular
Hotchkis (2012) Sport
32 tubular
32 tubular
Pedders (2010-2011) Balance Bar
27 solid (rear bar)
Pedders (2010-2011) FE3 package
27 solid
32 solid
Pedders (2012+) ZL1 upgrade, FE4 package
27 solid
32 solid
Pfadt (2010, 2012) Sport
25 tubular
35 tubular
QA1 (2010, 2012)
25 solid
22 solid
Whiteline (2010, 2012)
27 solid
27 solid
THIS THREAD IS UNDER CONSTRUCTION.
warn 145:159 ban
Old 01-06-2014, 07:59 PM   #2
Moreno1
Drives: G5.R
Good idea! Whether or not the sway bars are adjustable will help too.
Moreno1 is offline   Reply With Quote
Old 01-06-2014, 08:08 PM   #3
The_Blur
Moderator
The_Blur's Avatar
That would be good information. Right now, I'll have to start with the basics and get back to that eventually.
warn 145:159 ban
Old 01-06-2014, 08:43 PM   #4
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Looking for that 32mm Solid rear bar I see.
Firefighter is offline   Reply With Quote
Old 01-08-2014, 09:10 PM   #5
superdrummer38
Drives: Camaro 2SS/RS
LG Motorsports
Huge 35mm front and rear tubes
superdrummer38 is offline   Reply With Quote
Old 01-08-2014, 09:51 PM   #6
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
If I remember from my Engineering classes many decades ago, a tube is about 7/8's the torsional strength of a solid depending on material and thickness. Weight would be nice to know as well. a 35mm hollow may be about the same as a 32 solid, but much lighter. I just ordered a set of LG's. I know those and Phadt are 3 way adjustable on both ends. I know LG and Phadt are hollow.
tw78911sc is offline   Reply With Quote
Old 01-08-2014, 10:28 PM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
The Pfadt sport sways are 3 - way adjustable only for the rears. The front is not. Pfadt has another set of bars, but I can't remember if they are ZL1 spec or a Race spec (3 way adjustable front and rear)
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 01-09-2014, 04:11 PM   #8
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
35mm thats huge!!!!! Let us know how u like those lg bars . Good idea for a thread . .
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 03-01-2014, 09:37 PM   #9
AZ kevin
Drives: Black 2013 2SS
would there be a big difference in strength from a solid to a tubular ?
AZ kevin is offline   Reply With Quote
Old 03-01-2014, 09:55 PM   #10
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
LSR Sways
ZL1 spec sway- rear
CNC bent from tubular 1-3/8 inch DOM steel and then TIG welded with billet steel ends. Each end provides three adjustment positions for fine tuning of handling balance.
Compared to the factory ZL1 bar, the first position is the same as stock, position 2 is 10% stiffer, and position 3 is 26% stiffer.
If you are upgrading to this bar on an SS model, the first position is 76% stiffer than stock, position 2 is 100% stiffer, and position 3 will be 130% stiffer.
In addition we've also included greaseable, adjustable endlinks with heavy duty 12mm ball joints at each end to replace the rubber bushing endlink design found on the factory swaybar and other competitors swaybars. This eliminates compliant soft rubber in the factory endlinks allowing them to work more effectively, without adding any NVH (noise, vibration, and harshness).
Standard Front and Rear Bars-
LSR Performance’s adjustable swaybars for the 2010-2011 Camaro SS!! The only kit on the market designed and manufactured out of 4130 high strength chrome moly tubing and tig welded for maximum strength! Both front and rear bars are 3 position adjustable for ultra fine tuning of the suspension.
The bars feature billet and stamped ends that are welded on and not coined, which prevents unnecessary stress. High quality Energy suspension urethane bushings and brackets are included as well.
They are also powdercoated silver metal flake for a durable and long lasting finish. Speaking of long lasting, the LSR Performance bars feature a LIFE TIME WARRANTEE! So these will be the last set of swaybars you will ever have to purchase.
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 03-23-2014, 12:22 AM   #11
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The only way to calculate the torsional strength of a hollow bar is to know the thickness of the wall. Most hollow bars are in the .118inch thick tube range. This is due to pricing. The cost of the hollow tube material really starts to escalate as wall thickness escalates. Other tube size may max out at the .188inch range, which is a very aggressive bar, to a animal .250 range, which is usually not seen for street use. At .188 inch of wall thickness, the bar will be 30% stronger than a .118 inch tube. At .250 inch of wall thickness, the bar will be 45% stronger than a .118inch tube.
Solid to hollow aside, you will notice that the Camaro TEAM revisions to sway bars all show the rear bar larger than the front bar. This bias reduces understeer.
Understeer = slow
Oversteer = fast
What the numbers don't reflect is the change in rear bar geometry moving the mounting point from inside close to the differential to outside near the wheel. This FE4 change in geometry dramatically increased the efficiency of the rear bar. The 25mm front and 28mm rear bars on the ZL1 would require a 32mm rear bar with the original geometry.
Installing a set of 35mm front and rear bars does NOT reduce understeer. When shopping for new sway bars you want to be sure to convert your old FE2 and FE3 to the new style outboard mount rear bar to reduce understeer.
Old 03-23-2014, 12:52 AM   #12
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
23 solid
24 solid
27 solid
28 solid
25 solid
28 solid
25 solid
26 solid
Belltech (2010)
25 solid
BMR (2010) Xtreme
35 tubular
BMR (2010, 2012)
29 tubular
25 tubular
Eibach (2010)
29 solid
29 solid
Hellwig (2010)
32 tubular
25 tubular
32 tubular
35 tubular
32 tubular
25 tubular
32 tubular
32 tubular
27 solid (rear bar)
27 solid
32 solid
27 solid
32 solid
25 tubular
35 tubular
QA1 (2010, 2012)
25 solid
22 solid
27 solid
27 solid
Eibach (2010)tubular
L99CAMA2011 is offline   Reply With Quote
Old 03-24-2014, 03:50 PM   #13
detroitspeed
Drives: 1969, 70, 2010, and 2012 Camaros
Don't Forget Detroit Speed:
DSE (2010-2012 except ZL1)
28.5mm tubular (front bar)
DSE (2012 ZL1-2013+)
28mm tubular (front bar)
DSE (2010-2011)
28.5mm tubular (rear bar)
DSE (2012+)
35mm tubular (rear bar)
For the 2010-11 applications you can upgrade to a DSE 35mm rear anti-roll bar that includes the 2012+ DSE Rear Endlink Kit. You would also need to have a 2012+ GM rear lower control arm or the DSE Rear Lower Control Arm (recommended).
detroitspeed is offline   Reply With Quote
Old 03-25-2014, 01:23 AM   #14
Moreno1
Drives: G5.R
DSE (2010-2011)
DSE (2012+)
I've been waiting for you guys to pop in here! Welcome!
