TireRack
Old 02-02-2015, 05:14 PM   #1
The_Blur
Moderator
The_Blur's Avatar
Cost of Body Ports Installs?
I have some imperfect paint on my Camaro, and I was wondering if I could cut that off of my car and replace with ports, like the ones from ACS or 3dCarbon. Of course, that means I need more parts, paint, and help with install.
For those of you that did ports, how much did that run you to have a shop do it?
warn 145:159 ban
Old 02-02-2015, 10:37 PM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
nobody wants to help a mod out huh?
I don't think cutting is actually too hard tbh. might be worth a try
TommyTheCat is offline   Reply With Quote
Old 02-02-2015, 10:55 PM   #3
ChevyCamaroGirl
ChevyCamaroGirl's Avatar
Drives: 2010 CAMARO 2SS RS BLACK
My camaro has the ACS T3 ports. I had a local shop paint them and I installed them. You need to remove the fascia. I placed mine on two saw horse stands padded with styrofoam to prevent damage while I cut the port openings. If you're doing the T3's, they should come with a template and basic installation instructions. You will need some clamps and a cutting tool. I used my Dremel. The cutting was super easy, just be sure you get the template exact on both side.
ChevyCamaroGirl is offline   Reply With Quote
Old 02-03-2015, 05:58 AM   #4
The_Blur
Moderator
The_Blur's Avatar
I appreciate the input. I don't have a Dremel, so that's why I was considering letting a shop do this one. I'm considering the 3dCarbon fender vents, but I'm just gathering info. They include a template, too.
warn 145:159 ban
Old 02-03-2015, 07:24 AM   #5
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
The 3D Carbon fender vents are easy to install if you don't mind cutting into your car. I did mine with a cut off wheel on a angle grinder.. You just have to take your time so you don't melt the paint too bad. If I did them again I would use an air saw (I didn't have it at the time). Make sure you paint all the bare edges so it doesn't corrode. I also used a seam sealer around the inside of the whole vent to be safe.
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft
Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie
Eibach Springs & SS Sway Bars
| BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph
Superfly1 is offline   Reply With Quote
Old 02-03-2015, 11:11 AM   #6
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
You can probably buy a dremel for less than a shop will charge labor-wise. lol
Old 02-03-2015, 12:05 PM   #7
The_Blur
Moderator
The_Blur's Avatar
That may be the case, although I'd then have to find more uses for it.
warn 145:159 ban
Old 02-03-2015, 12:26 PM   #8
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
You'd be surprised at the things you can use a Dremel on. It is one of the handiest tools I've ever owned. They literally make about 100 different bits for the thing.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 02-01-2018, 10:52 AM   #9
The_Blur
Moderator
The_Blur's Avatar
It's time to revisit this topic.
I have some beautiful ACS primed bumper ports and am interested in anyone's experiences painting them. What did you do?
warn 145:159 ban
Old 02-01-2018, 11:18 AM   #10
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
I painted mine off the car and then just simply cut out the holes and dropped them i place. Was fairly easy and painless. Paint matching would be the hardest part depending on how many variances in paint codes.
and then glued and clamped in place.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 02-01-2018, 11:25 AM   #11
The_Blur
Moderator
The_Blur's Avatar
Yours came out incredible! I’m planning to paint mine satin or matte black.
Did yours come primed? Did you apply new primer or just paint?
warn 145:159 ban
Old 02-01-2018, 11:31 AM   #12
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Mine didn't come primed so quick coat of primer and then paint.
Seems like such a long time ago. Don't have this setup anymore
Old 02-01-2018, 11:54 AM   #13
orange devil
Drives: 2019 SS 2019 mustang GT
Hey if you need help painting those parts and install them in your bumper I wouldn't mind giving you a hand
orange devil is offline   Reply With Quote
Old 02-01-2018, 12:10 PM   #14
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
That first cut is always the hardest!!
