BeckyD @ James Martin Chevy
Old 10-26-2021, 11:55 AM   #29
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
New wheel bearings did not help the problem.
My suspension and alignment shop says that the steering shaft is oblong/ eccentric and does in fact contact the headers when the engine rocks back and forth on the engine mounts.
While I still don’t think this is the cause of the noise or vibration, Does anyone know if the steering shaft is supposed to be anything but straight?
This car was in a crash on the race track last year at this time And if you parts were replaced on the front end, mostly body parts and radiators and intercoolers.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-10-2021, 10:20 PM   #30
GunMetalGrey
So the long tube headers were making contact with the steering column, now that the engine has been shifted over slightly on the mounts, the noise is gone. I can’t believe how much it sounded like a rotating noise when it wasn’t
Old 01-23-2024, 08:43 AM   #31
Williamlkj
Drives: e92
I've replaced a wheel ball bearing on my Camaro after about 10 track days from https://nyzbearing.com/wheel-hub-bearings/. The symptoms were similar – a metal-on-metal noise when turning, especially under lateral G forces. It's strange that there are no visible marks, though.
Williamlkj is offline   Reply With Quote
Old 01-23-2024, 11:07 AM   #32
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Since this thread got brought up I now want to order some spare wheel hubs for my car but I'm having a hard time finding them.
The only ones I was able to find that is not out of order or discontinued was part number 13552403 from gmpartsdirect.com. I think this is the correct one, can anyone verify or does anyone have a source for the front/rear wheel hubs that is not out of stock.
Christian1LE is offline   Reply With Quote
Old 01-23-2024, 11:20 AM   #33
Christian1LE
I ended up ordering an older part number (13542187) from tascaparts.com since they had 10 in stock.
I ordered the fronts only for now.
Old 03-17-2024, 09:02 AM   #34
Janitims
Drives: camaro 6 2019
Bearings can be tricky – sometimes they fail without obvious wear marks. Heat from track days can do damage that's invisible to the eye. Glad you got it sorted!
Personally i use Bearing MFG and never faced any problem like this.
Janitims is offline   Reply With Quote
