Old 11-04-2014, 04:46 PM   #1
MightymouseSS
Drives: 2011 LS3
cam swap throwing cam position sensor code
I had a NF cam installed back in july. Recently ive been get a CEL for the cam position sensor. Thing is it'll come on for a few days then go away on its own. As far as drivability or hard starting these issues haven't occurred. Is this normal with a cam swap? My tuner said hes had this happen with certain grinds in the past. Any input will help CELs drive me crazy especially after being cammed.
Vararam
Stainless Works Headers
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Tuned by Southwest Speed
MightymouseSS is offline   Reply With Quote
Old 11-04-2014, 05:17 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
no issue here..
Old 11-05-2014, 10:56 AM   #3
Kelly@PCMofNC
Drives: 2010 RS/SS
No it's not normal to have that happen. Since the problem just occurred now and you have no hard starting/etc, I am going to assume you guys used the correct cam sprocket during the install. Is it an LS3 or an L99 to LS3 conversion?
Kelly@PCMofNC is offline   Reply With Quote
Old 11-05-2014, 12:39 PM   #4
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
When I have seen issues like this in the past, it can be a number of things.
Your cam position sensor is a magnetic pickup. So if there is a abnormal amount of metal in the oil, it will collect on the cam position or crank position sensors and block their "view" of the wheel. If the crank sensor is blocked, the car will not run. If the cam sensor gets bad enough it will be hard to start but the car will still run.
My suggestion first is to not drive the car until you can get to the front cover and pull the sensor out. Check to see if it has metal on it, or if it has had contact with something.
The other thing that can happen is the cam gear can come loose, and that will walk forward hitting the sensor. If that is the case, then you need to fix it, and do not drive or start it, until it is finished.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 11-05-2014, 03:23 PM   #5
MightymouseSS
Drives: 2011 LS3
Its an ls3 and a new 3 bolt sprocket was installed.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 11-05-2014, 03:28 PM   #6
MightymouseSS
Drives: 2011 LS3
Im taking my car back to southwest speed next Tuesday to have Ivan look into the problem. Hopefully it's not something catastrophic like other cammed cars have experienced lately especially with comp cores.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 11-05-2014, 04:34 PM   #7
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
What code is it giving you?
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 11-05-2014, 04:48 PM   #8
MightymouseSS
Drives: 2011 LS3
P0340
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 11-05-2014, 06:55 PM   #9
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Originally Posted by MightymouseSS View Post
P0340
Could be anything in the "circuit"
Look for any loose connections first. Can you clear the code? How soon does it come back?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 11-05-2014, 07:51 PM   #10
MightymouseSS
Drives: 2011 LS3
The code will come up then go away on its own. But when I scan it I get the p0340 cmp code.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 11-05-2014, 08:02 PM   #11
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
Ivan will get you fixed up. Im sure its something simple.
BLACK10 is offline   Reply With Quote
Old 11-05-2014, 08:56 PM   #12
MightymouseSS
Drives: 2011 LS3
Im confident Ivan will figure it out. Just wanted to see if anyone else had the same issue. Especially since I gotta tow my car 4 hrs to get the car to SWS. Ill be going back this Tuesday and mean while having a few other things done. Hopefully my next trip to SWS will be to have an ECS s/c installed and tuned.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 11-05-2014, 09:44 PM   #13
MightymouseSS
Drives: 2011 LS3
The code can be cleared. Its come up twice this month, so I cant give you a set time or mileage its pretty much random. Last time I was going across town code came up and on the way home it cleared itself. I dont wanna drive it till I get it checked out. I got a new sensor just in case.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 11-12-2014, 01:39 PM   #14
MightymouseSS
Drives: 2011 LS3
No metal or any contact on the sensor. Ivan at SWS is replacing it with a new sensor.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
